From what I have read accurate time alignment is not possible with a USB mic. Am i right in thinking that a USB mic amp is fine though? eg if the path is emm-6 mic -> behringer q502usb (or similar) with loopback on spare channel -> USB to computer
In this setup, what connects to the processor? The q502? In that case is the only way to send a signal to 1 channel at a time to manually move the connection from one analogue input to the next?
Is there any device [that would replace the mic amp in this chain] that provides multichannel connection in one wire?
If one has a built-in soundcard with optical or HDMI then is it still a valid setup to loopback the analogue line in/out but send a signal using the optical/HDMI output?
(A) You're assuming that the Behringer q502usb can be successfully used with REW ( all the while avoiding circuit feedback ) .
Since no one has currently posted ( here at HTS ) any reports about their success ( using the mixer with REW ) , I'd advise that you proceed with caution .
At the very least , only buy from a store with a liberal return policy ( who won't blink if you need to return the mixer ) .
(B) The necessary loopback circuit ( to create a timing channel for REW to use ) must be made between an Analog out & an Analog in ( both, BELONGING TO the SAME SOUNDCARD that the MIC is PLUGGED INTO/THRU ) .
- It must free of extraneous signals / such as the live mic pickup .
I can't answer your questions specifically with regard to time alignment. I don't know why a USB mic wouldn't work. As I think any USB bus lag could be compensated for. Anywho, unless you want to buy a Q502USB for other purposes I don't think it's going to work out for the REW measurements. Reason being is that the mic input signal cannot be separated from the main line out of the Q502 itself meaning that whatever the mic is reading is going to get pumped right into the lineout which is going to go into your AVR and that loop repeats.
Now, I'm not exactly sure why you couldn't just use the line/out headphone out of your laptop and bypass the Q502USB altogether.
I researched this pretty well because I really wanted to use a Q502USB as I have other purposes for it. I settled on buying a UMM-6 USB Mic from Cross Spectrum because at the end of the day, the cost isn't really any different. I can still buy a Q502 (or Q302 more likely in my case).
In fact, it wasn't until reading your post that I was aware of any possible issues with time based measurements and USB. Do you have any links to posts detailing this?
One won't be able to do timebased alignments with these / but then, 99% of the people posting here don't use the timing chnl feature for EQing their systems or subs .
If your current computer doesn't have an analog output then you need to get a small USB based ( 2-chnl ) soundcard to acquire output capability .
The Behinger UCA202 is popular around here . With it, you would need to move the output ( RCA ) cable from input channel to input chnl of your AVR . UCA202
The loopback ( for the timing chnl ) in this case would need to include ( one of ) the AVR's analog outs for the timing chnl to be of any use . Just remember, if you buy a USB based microphone, this is all a moot point .
FYI ( some perspective ), REW only added ( relatively recently, by including the "new" ASIO setting ) the ability to address chnls, higher the standard (1 of ) 2 choices ( that JAVA is limited to, when selecting input or output chnl-routing ) . As such, sending REW to an HDMI enabled sound-output is still a relatively new topic. . ( You should search this forum for clues on this question .) HDMI Search
If any of your laptops have an HDMI output on them, then you should experiment with REW ( & it's tone generator ) to see if you can access these outputs from within REW's preferences window ( & actually get output from REW , to your AVR ) .
You'll need ( assuming you're Windows based ) to download ( & install ) from ASIO4ALL their universal ASIO driver ( this is assuming your current soundcard within your laptop doesn't have an ASIO driver) .
Here's the direct download of the ASIO driver ; ASIO4ALL
I decided on the EMM-6 as I will need a fairly long run to the mic and didn't want to risk any issues with using a usb repeater. I don't think I understand why the loopback needs to be on the processor though if the onboard soundcard is doing digital out. It's probably a moot point though as I'll probably stick to analogue out & was thinking of picking up the tascam 122 mkii to drive it (the mic).
Thanks for the links about ASIO & HDMI, I will install & have a play. My laptop does not have hdmi out but my server does. I last tried HDMI with REW a year or so ago and it was not entirely happy, at least I couldn't get it work consistently despite usual windows (or linux, it's dual boot) audio working ok through it. I will give ASIO a try though to see if that works more reliably.
If I wanted to use HDMI, and given the use of non USB mic, then I think that means using the tascam purely as a mic amp and connecting it to the PC via a line input. However the benefit of HDMI is the ability to drive individual channels via software alone (if it works) but the main reason I want to drive individual channels atm is to investigate timing issues and that requires a loopback over an analogue interface to get the right data. Is that correct or am I missing something there?
If you buy the Tascam ( & find a way to use the HDMI output from your server ), the ASIO4ALL driver allows one to cobble together a composite driver, using different audio devices ( ie ; Tascam 122 for input , on-board graphics-audio card for output ) . This isn't ideal ( due to clock-drift from the 2 devices ) but it works well enough for REW ( due to the short durations of the test signal ) .
For a timing chnl to be accurate ( made via a loopback cable ), it must take into account the circuit ( A-D / D-A ) delays caused by the conversion circuits that are in actual use ( REW subtracts one channels delay from the other, to arrive at the delay of speaker to mic value ) . Therefore, the cable ( ins & outs ) must mimic your choice of where you are obtaining your analog, "ins & outs" .
:sn:
PS: A headphone output is the same as a line out .
Is there a reference available for what the options are with the ASIO driver? e.g. what is the meaning of the "timing reference channel" & what should it be used for? is there a way to correlate the named channels in the dropdown to the same named things in some soundcard config? I get 8 channels per hdmi device though, atm, I only get a signal channels 1 & 2 which equate to L and R. This might be processor config though it's not obvious what it could be (will need to experiment further).
IFor a timing chnl to be accurate ( made via a loopback cable ), it must take into account the circuit ( A-D / D-A ) delays caused by the conversion circuits that are in actual use ( REW subtracts one channels delay from the other, to arrive at the delay of speaker to mic value ) . Therefore, the cable ( ins & outs ) must mimic your choice of where you are obtaining your analog, "ins & outs" .
OK that makes sense. Why doesn't that mean one usually loops back across the soundcard & processor analogue interface? Is it just because the additional delay of an analogue connection is trivial? Just to be clear this would mean I need to connect from an processor analogue output (any unused one will do?) to the soundcard line input?
am I correct in thinking this means, given my 5.1 setup, I can select channel 7 as the timing source and loopback from the corresponding pre-out on the processor to the line in on the soundcard?
- Yes ( assuming the AVR hasn't "muted" outputting signal on #7 for some reason / such as turning off all channels that it "senses" aren't being used ) .
For those of us new to taking room measurements, what exactly does the loopback timing channel do for you? If one were to have a USB measurement mic, that can't be utilized, could they use any generic microphone for timing related functions (i.e., is frequency response critical for these measurements)?
Related Threads
742.3K posts
170.9K members
Since 2006
