REW Forum
Parasitic mains?
Discuss Parasitic mains? in the Equalization | Calibration forum; Parasitic mains? I'm still learning, but was surprised to see that when I added my mains in, I got a lower sound ...
Views: 475 - Replies: 5
Old 10-10-07, 03:01 PM   #1
Alias: toecheese
Loc: Raleigh,NC
User: #356
  toecheese is offline
Parasitic mains?
I'm still learning, but was surprised to see that when I added my mains in, I got a lower sound level. Is that a phase problem or perhaps a crossover problem?
My crossover at the receiver is 100, the speakers are all set to small.
Red is sub only, blue is mains only, black is combined.
Old 10-10-07, 08:35 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: Parasitic mains?
One and the same. Play with the sub phase to eliminate the dip. You can also move the sub distance trim in your receiver a bit too, if phase doesn't work.
Old 10-10-07, 08:58 PM   #3
Alias: toecheese
Loc: Raleigh,NC
User: #356
Un?fortunately, my sub is an IB. I did notice that moving my sound meter to a different part of the room really changed the curve- though it was still parasitic.
What I meant by crossover was the setting on the receiver. For my sub, about the only thing I can do is do it wholly 180 degrees out of phase (reversing the leads).
I'll give that a try.
Is my huge dip at 58 due to a room null? It occurs even without the mains.
Old 10-12-07, 01:35 PM   #4
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Probably is, seeing how narrow it is.
I’m assuming your receiver can’t do delay adjustments?
Is your sub closer to the listen position than the mains? If so, you might get a pro-audio effects processor that could dial in the delay factor you need. Alternately, PPI used to make an analog phase unit for car stereos that you could try for the mains, if they’re what's needing the delay. They don’t make them anymore, so you’d have to eBay it.
Old 10-14-07, 09:39 AM   #5
Alias: toecheese
Loc: Raleigh,NC
User: #356
What do you think about just 180-ing the woofer?
Old 10-14-07, 06:10 PM   #6
Alias: toecheese
Loc: Raleigh,NC
User: #356
I re-set my speaker distances and the curve looks much better now, no 180 needed.
Thanks!
