| REW Forum Question on -3dbfs output levelDiscuss Question on -3dbfs output level in the Subwoofer Equalization | Calibration forum; Question on -3dbfs output level I want to test the max that I can push my sub without bottoming or distortion at 20 hz, so ... |
| | #1 (Link) | |||
| Question on -3dbfs output level I want to test the max that I can push my sub without bottoming or distortion at 20 hz, so I can calibrate in a house curve from there. I just want to confirm that I am on the right track. If I have all my gains and volume levels at the same spot, as when I watch movies, and play a sine wave at -3dbfs, this would be the same as the max level that would be output while watching a movie? Thanks | |||
| | #2 (Link) | ||||
| Re: Question on -3dbfs output level Quote:
brucek | ||||
| | #4 (Link) | |||
| Re: Question on -3dbfs output level Ahh OK. Well, I suppose if the Wave and Output level (that is used in the soundcard when in the movie mode), is the same as in REW, then -3dB should be just below that threshold. Should work. brucek | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Low Level, High Level? | linwin3000 | DIY Subwoofers | 4 | 09-29-07 12:47 PM |
| Question on ratshack meter and sub level. | cruzmisl | SPL Meters | Mic's | Calibration | 3 | 09-28-07 01:39 PM |
| Sub Output On Latest Receivers | Mike P. | Home Theater Components | 3 | 09-18-07 11:08 AM |
| Can't get any output using REW Please HELP!! | Julien43 | REW Forum | 18 | 04-27-07 02:44 AM |
| Question about Set Target Level As... option | lovingdvd | REW Forum | 5 | 01-25-07 04:12 PM |
