REW Forum
Need to calibrate RS SPL for rew?
Discuss Need to calibrate RS SPL for rew? in the Equalization | Calibration forum; Need to calibrate RS SPL for rew? Probably a dumb question but as a newb to REW I'm a bit confused. I've got a RS 33-2050 analog ...
Views: 492 - Replies: 3
Old 10-16-07, 07:57 PM   #1
Alias: duxfan
Loc: Orange County, CA
User: #12336
Since: Oct 2007
  duxfan is offline
I've got a RS 33-2050 analog meter and I'm not sure if I need to calibrate the meter prior to making measurements (on my subs) with REW. I'll be using a DSP1124P and wondered if I need to use the RS SPL calibration corrections or ???
Thanks in advance!!!!
Old 10-16-07, 10:35 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Need to calibrate RS SPL for rew?
I trust you've read REW HELP files. They are well written and are a wealth of information.
You will need to download the correct meter calibration file from our download page and load it into REW.
Old 10-16-07, 10:50 PM   #3
Alias: duxfan
User: #12336
Since: Oct 2007
  duxfan is offline
THANKS!!!
I read the help files, but still wasn't sure if I needed to run my own calibration, or simply (it seemed too simple) load the .cal files.
Again, thanks!!!
Old 10-16-07, 11:10 PM   #4
Alias: brucek
User: #6
  brucek is offline
You do need to run the soundcard calibration routine though, to create a cal file specific to your card....
