Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
Can't get REW set up... strange stuff
Discuss Can't get REW set up... strange stuff in the Subwoofer Equalization | Calibration forum; Can't get REW set up... strange stuff Hi, I've been trying to get REW set up to measure my subwoofer response so I can generate some filters ...
Old 06-14-06, 07:31 PM   #1 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Hi,
I've been trying to get REW set up to measure my subwoofer response so I can generate some filters for my BFD but I'm having problems. I'm using my built in sound which has DD 5.1 and I'm using the digital coxial out and the mic in.
1. When I connect the Radio Shack analog meter to the mic input the meter then reads totally differently than when it isn't plugged in. Basically it always has a reading, even when there is no audio or test tones. Should I have it unhooked when I set the measurement level so I can actually get a reading?
2. I can't get my sound card to calibrate. It gives back a graph that looks like a feedback loop but I can't find any option to fix that.
Help
Old 06-14-06, 07:39 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Can't get REW set up... strange stuff
You must use the LINE-IN input and not the MIC input. The RS Meter outputs line level.
Old 06-14-06, 07:40 PM   #3 (Link)
Platinum Member
Alias: Darren
Loc: Washington
Darren's Avatar
User: #43
Darren is offline
Interesting, I couldn't get a reading with the line-level input....I'll try again. I couldn't calibrate until I used the mic. I'm using a mono mini-jack, do I need a stereo one?
I think I just figured it out, It appears it does indeed need to be stereo, I was able to get a reading momentarily by jiggling the mono plug so I assume it's contacts need to be stereo.
EDIT:
Well, I got it to calibrate the soundcard once but wanted to go through the whole process again and after that it won't calibrate again.
From the instructions:
Connect the soundcard's line output directly to its line input - use the channels that will be used to make system measurements
So, does that mean I should use the digital coaxial out to the line-in? I can't get a reading doing that but if I go from the line out to the line in I do get a reading but it only worked once.
Old 06-14-06, 09:37 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Nope, you don't use digital. You can't create a soundcard cal file with it.
You use analog line-out to analog line-in.
As you've discovered, you must use stereo 1/8" plugs, but only use one channel. A stereo (1/8" to two RCA) adapter works best. Then you just hook up one RCA cable.
Sometimes the soundcard cal is funny. If it gets in a funk, clear the soundcard cal data with the REW pulldown (Soundcard pulldown and select Clear Calibration Data) and then restart the program and try and create the file again.
Old 06-15-06, 05:31 PM   #5 (Link)
Alias: Snookboy
User: #238
Snookboy is offline
Bruce,
I could use some clarification on this. What cable needs to be stereo? From the SPL meter to the sound card line in or when you connect the line in to the line out for sound card measurement? Or both? Or from the line out to the processor and/or BFD? The reference to channel also has me puzzled. There is only one line in on my sound card. Channels are not an option, nor are they on the meter of course. On the line out I have three choices: one for front L/R, one for rear L/R, and one for center/sub. I am using the front L/R using a cable with an 1/8" on one end and two RCA plugs on the other. The two RCA plugs I am connecting to a L/R input on my processor.
So I have an RCA from the SPL to an RCA/1/8" adapter to the line in on the sound card. I have the front L/R of the sound card (single 1/8 connection) to the L/R input on the processor.
This seems correct to me, however, if I have all sources but line in muted on the sound card, I have no sound. I have to unmute the WAVE source.
Thanks Bruce.
Old 06-15-06, 07:24 PM   #6 (Link)
Alias: brucek
User: #6
brucek is offline
Snookboy
Here's the diagram (from the REW help file) for the hookup to your soundcard and receiver and BFD.
Notice the adapters in and out of the soundcard are both 1/8 stereo. but you only use a single channel (either left or right) in and out of the soundcard. Be sure to select the same channel in REW (left or right) that you have the cable hooked to. Normally everyone uses right. You also use the same right channel for the soundcard calibration routine (that you only do once and then save the file).
I know there is only one line in and one line out on your soundcard - but they're both stereo with two channels (Left and Right).
Yes unmute the wave.
If you don't like those heavy 1/8" stereo to RCA adapters you can get a cable type like this:
It's still a stereo 1/8" to two RCA connectors.
Still confused?
Old 06-15-06, 08:19 PM   #7 (Link)
Alias: Snookboy
User: #238
Snookboy is offline
Bruce,
I appreciate your patience. If that picture is from the REW help file, I must have an old version, because I have been pouring over that thing and have not seen that illustration. It explains it perfectly. Thanks a million.
Old 06-15-06, 08:38 PM   #8 (Link)
Alias: brucek
User: #6
brucek is offline
Yeah, it's the help file in the sticky REW Links and FAQ section at the top of the BFD forum:
http://www.hometheatershack.com/room...tml/index.html
Old 06-15-06, 10:40 PM   #9 (Link)
Alias: Snookboy
User: #238
Snookboy is offline
Ok, I was using the help from the program...did not see this. Thanks.
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
