| REW Forum WaterfallsDiscuss Waterfalls in the Subwoofer Equalization | Calibration forum; Waterfalls Doug Plumb wrote:
NASA or any other company does not ever use waterfall plots to evaluate the response of their ... |
| | #26 (Link) | ||||
| Re: Waterfalls Quote:
| | #27 (Link) | ||||
If you have a resonance and can't correct it with one filter then you need more than one, this becomes apparent only after one filter is used and you cannot ideally dampen the resonance. This occured in my room at about 140 Hz. There are three sharp resonances right around that area, easily identified with curve fitting. Oil exploration, etc look almost exclusively at non minimum phase behavior under which conditions a waterfall plot may apply. I think that generally we should encourage users of our kind of software to look only at frequency response because the distortions associated with waterfall plots are usually poorly understood. | ||||
| | #28 (Link) | |||
| Re: Waterfalls But isn't this why the room acoustics is so important? One should not have to apply more than one filter to correct a resonance at one frequency if the room is doing its job! My belief is if you have to apply multiple filters for a narrow frequency spike or bump, it's the room or a very poorly designed sub driver or enclosure "ringing". Granted it still has to be corrected for the system to sound "right" but not multiple filters. My engineering degree is not in acoustics, so this is just my opinion. ![]() | |||
| | #29 (Link) | |||
| Re: Waterfalls You cannot have a reasonable room treatment if say you have a problem at 30 Hz... Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||
| | #30 (Link) | ||||
You don't need multiple filters to correct - you can just put a big notch in for low frequencies if you want. | ||||
| | #31 (Link) | ||||
I still don't believe that using a big notch filter would be a final answer,...temporarily, yes. But long term you're going to get tired of it and will want to address what is causing that big bump. So this is where I agree with brucek and the use of waterfall plots because we are dealing with an analog device that behaves like a car's suspension or sub in this case (spring & shock absorber). Remember the big old "American" sedans and how their suspensions behaved,...excellent frequency response most of the time, but throw in a curve or mid corner bump and they became unsettled, and that's why I believe in this instance waterfall plots are useful. | ||||
| | #32 (Link) | |||
| Re: Waterfalls Hi, I would like to understand whether to intervene: I don't succeed in flattening the 153 Hz blade (DEQ2496) (2 of my Ht satellites about 6 ft convergent, microphone to the center) Red waterfall toslink input; Green waterfall DEQ equalization + FBD - 6 dB@158Hz 1/60 oct Yellow waterfall DEQ equalization + FBD - 30 dB@158Hz 1/60 oct Orange waterfall DEQ equalization + FBD - 30 dB@158Hz X 3 1/60 oct. where am I wrong? thanks EDIT amrvf: excuse me, soundcard not calibrated!!! (not loopback but microphone signal!!!) Last edited by amrvf; 11-14-07 at 05:00 PM. | |||
| | #33 (Link) | |||
| Re: Waterfalls I would say the peak is far too narrow to even hear. Filters of 1/60th of an octave are far too narrow to be useful. Small microphone movements at that frequency would change the result. Looks like the signal may be room noise. brucek | |||
| | #34 (Link) | |||
| Re: Waterfalls I'm back. Thanks for the earlier responses. Here are some fresh waterfall plots of my 4 x 15" IB in a very non-parallel 27' attic with multilevel floors, an open stairway in the floor. Ceilings, floor and 45 degree walls are all boarded. Listening position no BFD: ![]() Listening position with BFD including +16dB boost @ 20Hz 120/60. ![]() Nearfield with BFD. ![]() Any useful thoughts? ![]() | |||
| | #36 (Link) | |||
| Re: Waterfalls Brucek wrote earlier in this thread: "As a side note, you can see what a completely terrible idea it is to add a gain filter to boost the level of a sub at low frequencies. You do nothing more than emulate a room mode at the gain frequency" In Chrisbee`s second waterfall in the post above he has gained 20 hz with 16 db. I cant see that this has emulated a room mode at the gain frequency. The room mode seems to be the same as the higher frequencys. | |||
| | #37 (Link) | |||
| Re: Waterfalls You may find this an interesting comparison: Measured at the listening position: ![]() Here I have replaced my original 32Hz drivers with four brand new 16Hz drivers from AE. BFD settings have been reset from the massive +16dB @ 20Hz boost required before. I wanted to continue the new slope into the infrasonic to match my normal listening levels. Fletcher-Munson, Equal loudness etc. A wide trough existed between the 12Hz room mode and ~25hz. I filled this with another quick and dirty boost filter at 20Hz.. Trial BFD Filters are: 20Hz + 5dB BW35. 25+2Hz -6dB BW20. 40Hz -4dB BW30 50+5Hz -3dB BW20 | |||
| | #38 (Link) | ||||
| | #39 (Link) | |||
| Re: Waterfalls In the first post... Am I the only one that finds it odd that the decay rate of your BFD is over 100ms? I understand that some shape is expected for a bandwidth limited spectrum, but that long? -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | |||
| | #40 (Link) | ||||
A loopback cable (with the BFD removed from the circuit) will show exactly the same result. Isn't the 100ms that you refer to a function of the duration of the impulse response analyzed? For example, if connect a loopback from line-out to line-in of the soundcard and sweep a measurement to 200Hz, and increase the duration of the gate out to 1000ms (1Hz frequency resolution), I would get the following result. waterfall 1000ms duration.jpg But if I decrease the gate to 100msec (10Hz frequency resolution), I would get the following result. waterfall 100ms duration.jpg brucek | ||||
| | #41 (Link) | ||||
Are you saying that you only did the sweep up to 200Hz? If so, that might explain it. Why aren't you sweeping to the top limit of your soundcard? Regardless, simply increasing the volume on the BFD is going to make it seem like it takes longer to decay. The fact that your EQ shows the same thing simply verifies that it is achieving an amplitude change...not so much changing the ringing at that frequency. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | ||||
| | #42 (Link) | ||||
Sorry, I'm not sure what you're disagreeing with, or even what point you're trying to make? ![]() brucek | ||||
| | #43 (Link) | |||||
What I'm trying to point out is that the EQ does not ring or resonate or whatever you want to call it. It is not changing over time. You are misinterpreting an artifact of the waterfall calculation. For a given point in the room where reflections arrive within a wavelength of the frequency in question, the system could be simplified as minimum phase. EQ only works in minimum phase situations. However, you have not shown that the standing waves have been removed. In fact, they are most certainly still there. The easiest way to verify that the standing waves are still there is to locate the nulls of the standing waves...which do not move to different positions in the room or change frequency as EQ is applied to the signal. I suppose you could just not sit in the nulls, but it's not quite so easy. The point I was making above is that you're only minimum phase for a single location in space. If you move the microphone even a few inches (like the width of your head), your EQ no longer works perfectly. Sure, some might argue that it is a small compromise, but the point is that it's not perfect. Proper acoustical treatment gets rid of the standing wave, which in turn improves the situation at far more locations in the room (it's not perfect either, but the compromises are much less). One more comment which has to deal with psychoacoustics. When you walk into a room, there is a certain sonic characteristic to that room, even with no music playing. When you use EQ on the music to try and not trigger behaviors in the room, you end up sending conflicting signals to the listener who is partially expecting that bass guitar to sound like it would sound in their room. In other words, when you sit there listening to music, you are partially going to be identifying some attributes of the sound as being the room and not the music....if your music is precompensated for the room, and then your ears compensate what they hear from the room, then you end up with double compensation and the music sounds disconnected. Perception is definitely different for everyone, but the point is that it's much easier when the room isn't imparting crap on the sound because then there is never any amount of the listener trying to filter it out - it just sounds way more natural. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | |||||
| | #44 (Link) | |||||
The modal response of a room acts exactly like a 2nd order filter and matches the BFD generated filters in all aspects. At modal frequencies, a room resonates in gain and Q exactly as if you fed a sub signal through a 2nd order parametric filter. This fact allow us to fashion an identical 2nd order filter with the opposite gain and bandwidth that matches the room mode so it will completely disappear (at the point of measurement). This doesn't apply outside the low frequency range where signals are no longer considered minimum phase, where primary reflections (second order) from the walls, ceiling and floor arrive at the listening position anywhere in the room with a phase shift of quite a bit less than a cycle. So, the effective limit here of about 80Hz-100Hz is reasonable for equalization in most rooms...(an 80HZ signal has a wavelength of about 14ft)............ Quote:
brucek | |||||
| | #45 (Link) | |||
| Re: Waterfalls How often does it show up where EQ predictions are made that do not result in the measured outcome? If the system were minimum phase, wouldn't the measurements correlate exactly with the predictions? Whenever this happens, one might argue that making the frequency response as flat as possible doesn't lead to the most accurate reproduction. Of course this notion is nothing new - there are articles dating back into the 70's. There are also articles that discuss windowing limits for low frequency waterfalls too - it's a tradeoff between time and frequency resolution (can't have both at the same time). I'll see if I can't find that article too, but basically the data is meaningless without a proper window and obviously in this case, the wrong window is being used because it's showing decay rates that cannot be true. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | |||
| | #46 (Link) | |||
| Re: Waterfalls The main factors determining the shape and behaviour of the waterfall plot are the types and durations of the window functions used. The main window function is a right half window whose type is set by the Low Freq Decay window selection in the Analysis settings (default is Tukey 0.25) and whose duration is governed by the window control below the waterfall graph. The key to the observed behaviour of the waterfall is the window function applied to the left edge, which is not user-selectable. It is a left half Hann window whose duration is half the selected window duration (making for a total duration of 1.5 times the value in the control). This value was arrived at empirically by trying various settings to find a value that makes it easy to distinguish modal effects in measured data. I may make this a user-configurable parameter in a future build, but the current settings work well for the intended purpose of this plot. | |||
