REW ForumDiscuss Waterfalls in the Equalization | Calibration forum; Waterfalls Nick, brucek’s graphs were presented as a visual aid for his narrative. No, the Behringer does not add ringing to ... |
Views: 11540 - Replies: 161
| | #51 | |||||
| Re: Waterfalls Nick, brucek’s graphs were presented as a visual aid for his narrative. No, the Behringer does not add ringing to an electrical signal, nor does any other equalizer. It’s the room that does that. Don’t let all the theory confuse you. It’s easy enough to take your own REW readings and compare equalized to baseline and see what you get. Quote:
Regards, Wayne | |||||
| | #52 | ||||
| Re: Waterfalls Just check my small experiment supported with graphs at the beginning of the thread ...This is not a simulation but true measuements ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #53 | |||||
| Re: Waterfalls Quote:
Now, there are of course other reasons to use boost judiciously or not at all, including maximizing the signal to noise ratio through the BFD (although I believe one has to look at the entire system's S/N ratio, also), and the fact that boosting a null eats up your sub amp's headroom (needlessly, if you really have a null that does not respond). However, a little boost can be used to treat a low line level output from the BFD, which was my problem with using just cuts. Unfortunately, I think there needs to be a case-specific evaluation by each person as they tweak their system. Luckily, there forum is available to guide people along the way. Pete Last edited by PeteD; 12-26-07 at 10:54 AM.. Reason: Confused myself! | |||||
| | #54 | |||||
ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||||
| | #55 | ||||
| Re: Waterfalls Perhaps polarity is the right way. Here's what I'm thinking. Run the second sub through a bandpass filter with center frequency the same as the room resonance. The second sub would have the polarity inverted. Sorry I don't have a second sub to try. Nick | ||||
| | #56 | ||||
| Re: Waterfalls I should mention that there is absolutely no doubt that the BFD is NOT introducing any kind of ringing when the filter is boosted. What we're seeing is precisely the effects of the window used to generate the waterfall...not what's happening in real life. I brought it up to point out that changes in amplitude can pretend to show differences in ringing (as so clearly demonstrated for us). Since we know that no ringing is added when a frequency range is boosted, we can use the graphs to normalize what constitutes no change in decay when amplitude is changed. In other words, any EQ added to your subwoofer is going to show the exact same difference on the waterfall that the EQ made....and it's not because the EQ magically made the room ring less. Likewise, any natural amplitude variations with the subwoofer will also show up as ringing (and dips will show up as decaying faster). -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | ||||
| | #57 | ||||
| Re: Waterfalls That's not correct. The windowing effects are the cause of the response across the freq band not dropping sharply to the noise floor when no filters are active, but every EQ filter (gain or cut) rings at its centre frequency, the higher the Q (the narrower the bandwidth) the longer it rings. The ringing is easily observed in the impulse response by setting up the BFD in loopback and making a measurement with a sharp filter, it is more obvious with boost than cut but both ring. It is because of this time domain behaviour that EQ filters are able to counteract the ringing of modes, the decay of the EQ filter's attenuation over time matches the decay of the mode's gain, when the filter is properly set to match the mode's bandwidth and gain. | ||||
| | #58 | |||||
What is the ideal decay rate (or realistic desired decay rate where sound quality is not compromised - i.e. we obviously aren't listening in anechoic rooms), or do we just want it to be relatively even across the frequency response? I guess could also be said that boost in particular should be performed at as wide a bandwidth as possible, with subsequent cuts to included peaks, instead of boosting individual dips - which is more likely to introduce ringing? This is a very informative thread - it motivated me to pick up a sound card yesterday. Pete | |||||
| | #59 | |||||||
| | #60 | ||||
| Re: Waterfalls John, where do phase changes from filtering fit into the picture? I lifted this from Rane’s Exposing Equalizer Mythology note. The bolded text (emphasis mine) pretty much reads like what you’ve often stated here at HTS, except he’s talking about phase shift, not modal ringing. Comments? Phase shift is not a bad word. That it has become a maligned term is most unfortunate. This belief stands in the way of people really understanding the requirements for room equalization. The frequency response of most performing rooms looks like a heart attack victim's EKG results. Associated with each change in amplitude is a corresponding change in phase response. Describing them as unbelievably jagged is being conservative. Every time the amplitude changes so does the phase shift. In fact, it can be argued that phase shift is the stuff that causes amplitude changes. Amplitude, phase and time are all inextricably mixed by the physics of sound. One does not exist without the others. An equalizer is a tool. A tool that allows you to correct for a room's anomalies. It must be capable of reproducing the exact opposite response of the one being connected. This requires precise correction at many neighboring points with the associated phase shift to correct for the room's opposing phase shift. It takes phase shift to fix phase shift. Simple as that. One way people get into trouble when equalizing rooms is using the wrong type of equalizer. If an equalizer is not capable of adding the correct amount of phase shift, it will make equalizing much more difficult than it has to be. The popularity of the many constant-Q designs has come about because of this phenomenon. Equalizers that produce broad smooth curves for modest amounts of boost/cut make poor room equalizers, and good tone modifiers. They lack the ability to make amplitude and phase corrections close together. Lacking the ability to make many independent corrections with minimal interference to neighboring bands restricts their usage primarily to giving a shape to an overall response rather than correcting it. Serious correcting requires sharp constant-Q performance, among many other things. Only by adding many precise, narrow phase shift and amplitude corrections do you truly start equalizing a system's blurred phase response. You do not do it with gentle smooth curves that lack the muscle to tame the peakedness of most rooms. Broad smooth curves do not allow you to correct for the existing phase shift. Its just that simple, you must pre-shape the signal in both amplitude and phase. And that requires narrow filters that preserve their bandwidths at all filter positions. Regards, Wayne | ||||
