REW ForumDiscuss Waterfalls in the Equalization | Calibration forum; Waterfalls That seems to somewhat contradict your general advice to use broad filters, Wayne. I use your advice with good results, ... |
Views: 11541 - Replies: 161
| | #61 | ||||
| Re: Waterfalls That seems to somewhat contradict your general advice to use broad filters, Wayne. I use your advice with good results, but whatever works.. I'd like to know more about this. | ||||
| | #62 | ||||
| Re: Waterfalls The amplitude and phase response of EQ filters is inextricably linked. What the passage says is use narrow filters to counter narrow effects, i.e. modal resonances. To counter a mode the corresponding filter needs to match it precisely, which is why smoothing should not be used when viewing responses with the aim of addressing room modes. The waterfall plot is a good indicator of whether a filter's bandwidth and centre frequency are correct to deal with a mode - it is difficult to do this with the initial response alone as the overlapping effects of the various modes can make it hard to separate them, as the waterfall progresses the strongest modes (which most need correcting) stand out as the response around them decays, making it easier to work out the filter settings needed to address them. All that is not an argument against broader filters for response shaping, that is another tool in improving the overall response and the only one that can be usefully applied above about 200Hz as modal eq filters would only be effective over a very small area at such frequencies. Both should be combined with careful placement of speakers and listener to start with the smoothest response that can be practically achieved in the space and whatever room acoustic treatment can be accommodated, even sympathetic choice of furnishings, drapes etc can be very beneficial. | ||||
| | #63 | |||||
| Re: Waterfalls Okay, so basically phase shift and modal ringing are the same thing. So in essence what the Rane man is saying here... In fact, it can be argued that phase shift is the stuff that causes amplitude changes. Amplitude, phase and time are all inextricably mixed by the physics of sound. One does not exist without the others. ...is that change in modal ringing (phase) from an equalizer is no big deal. I agree. ![]() Quote:
Only by adding many precise, narrow phase shift and amplitude corrections do you truly start equalizing a system's blurred phase response. ...for one, I don’t know of anyone who makes an equalizer like that – i.e., allows for numerous highly-precise filters. Second, I assume he would know that it would be impossible to achieve this for every location in a room. Third, from what I understand, room modes as we know them in our little rooms are not a significant problem in the large rooms you typically see in Rane’s world. Regards, Wayne | |||||
| | #64 | ||||
| Re: Waterfalls Am I the only one who has “repeatability” problems? A measurement I take say, today is a little different than what I got back in the summer, or even last week - different enough for REW to generate slightly different modal filters. Which are the precisely-perfect filters for the room mode? Regards, Wayne | ||||
| | #65 | |||||
| Re: Waterfalls Quote:
I know the bass is not as twitchy as the mids and highs etc when the mic moves just a bit, but are the minor changes in the bass from different mic positions enough to account for what you are talking about? | |||||
| | #66 | ||||
| Re: Waterfalls I'd say screw EQ for anything over deep bass, and treat the room! That's what I do, and I'm very happy. I do one filter at 33Hz and that's it! | ||||
| | #67 | |||||
![]() ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | |||||
| | #68 | |||||
| | #69 | ||||
| Re: Waterfalls John, Is there any particular reason why these graphs are displayed in a 300 ms window and not some other value? Regards, Wayne | ||||
| | #70 | ||||
| Re: Waterfalls That's just a convenient starting point that is often suitable for looking at low frequency behaviour, can dial in whatever window width and time span you find appropriate, bearing in mind that shorter windows decrease frequency resolution (the resolution is shown next to the window control). | ||||
