| REW Forum External soundcardDiscuss External soundcard in the Subwoofer Equalization | Calibration forum; External soundcard Hi Guys,
Ok, Eventhough my wife is going to turn me into a soprano for all the stuff I am ... |
| | #1 (Link) | |||
| External soundcard Hi Guys, Ok, Eventhough my wife is going to turn me into a soprano for all the stuff I am buying, but its a small price to pay. Ok here we go, I have the BFD1124p on its way, also the UB802 mic pre amp and the ecm8000 mic. Outside of suitable cables, I am going to need an external sound card for my lap top, which will go into the USB connection. My Question is, Will REW interface with a usb sound card and if so, Can someone recommend a card to do the trick. Regards Peter ![]() | |||
| | #2 (Link) | |||
| | Re: External soundcard soprano run fast... Several of us here use the Creative Soundblaster MP3+ USB Sound Card and it works great. You can find them new for around 40 bucks. Creative will have refurbished ones on Ebay for 15-20 bucks quite often, so you might check there. A popular interface is the Edirol UM-1X USB/MIDI interface. It appears the Edirol UM-1EX may be its future replacement. You'll also need a 10-15' MIDI cable to go from the interface to the BFD. I generally search Froogle for these kinds of things to find the cheapest price. Sort your search for lowest to highest pricing. | |||
