Help with REW - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Exodus Audio
REW Forum
Help with REW
Discuss Help with REW in the Subwoofer Equalization | Calibration forum; Help with REW I was wandering if anyone could point me to a thread or help me with REW without a BFD device. ...
Old 11-06-07, 01:04 PM   #1 (Link)
New Member
Alias: rock
User: #13154
Since: Nov 2007
rock68 is offline
Help with REW
I was wandering if anyone could point me to a thread or help me with REW without a BFD device. I just want to graph my sub with a laptop, receiver, and SPL meter if possible. Not sure what connections I need as in adapters and such and how to run through the receiver. Hopefully I don't need an external sound card. Thanks!
Old 11-06-07, 01:29 PM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Re: Help with REW
Hi rock,
Not sure if you had a chance to read the help files. Here's the link for the REW files, and here's the link for the BFD itself.
You won't need an external sound card if your existing card has a line out and a line in -- but you can't use "mic in" for the input. As long as you have line out and line in, it'll most likely be fine.
Have a look at the help pages and let us know if you have any questions.
Good luck!
-- Otto
Old 11-06-07, 01:31 PM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Help with REW
I suspect you will need an external soundcard, since most laptops only have a microphone input and REW requires it have a line-in jack.
Take some time and read the setup section in The REW HELP FILES. The connections are shown there.
Generally, you feed the line-out of the soundcard into the AUX or CD input of your receiver, and then you feed an SPL meter (Galaxy CM140 or RadioShack models) into the line-in of the soundcard.
Old 11-06-07, 02:05 PM   #4 (Link)
Alias: Spridle
Loc: Houston, TX
Spridle's Avatar
User: #11331
Since: Sep 2007
Spridle is offline
Re: Help with REW
I have a Dell Laptop that came with a built-in Crystal WDM souncard. It only has 3.5mm jacks for microphone and headphones (no line-in or line-out jacks). REW works fine for me the Radio Shack meter. I can also use a calibrated microphone with an AudioBuddy preamp/phantom with no problems.
Old 11-06-07, 02:41 PM   #5 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Help with REW
Yeah, sometimes you can get away with it. SPL meters output a line level and a microphone input is looking for a very low signal level. Offtimes the mic inputs also provide a +5 volt phantom signal that may be a problem to the SPL meter.
The mic inputs offer very high gain, and as such are quite noisy. They usually suffer from very poor frequency response and so a soundcard calibration can be quite problematic. I don't know that I would trust the response from using a mic input. I would certainly check the impulse response to ensure my signal was sufficiently above the noise, and I would ensure a loopback test of a cable was flat after calibration.
For the price of an external soundcard, I wouldn't attempt a measure with a mic input.......
Old 11-06-07, 04:17 PM   #6 (Link)
Alias: Spridle
Loc: Houston, TX
Spridle's Avatar
User: #11331
Since: Sep 2007
Spridle is offline
Re: Help with REW
My soundcard calibration is +/- 1dB from 20-20KHz. Also, here is an impulse graph generated from a 20-20KHz sweep of the loudspeakers and measured with a mic connected to the microphne input of the soundcard. Not sure what this graph tells me.
Old 11-06-07, 05:05 PM   #7 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Help with REW
Great, I'm glad it worked out for you. I can't see the graphs too well because they are so small, but I'm sure its fine. Most aren't so lucky using a mic preamp with a line level input.
Old 11-07-07, 09:36 AM   #8 (Link)
New Member
Alias: rock
User: #13154
Since: Nov 2007
rock68 is offline
Re: Help with REW
Thanks for the input guys. It's going to be slow to get this going but hopefully I'll have time soon. I am trying to get this setup and running on my current setup so I'll be ready when my PB13 comes in. Thanks again!
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
