Problem setting target level - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
Discuss Problem setting target level in the Subwoofer Equalization | Calibration forum; Problem setting target level When I try to Set Target Level I get the following error: The SPL using the speaker calibration signal is ...
Old 06-17-06, 05:25 PM   #1 (Link)
Alias: jimsfield
Loc: SLC
User: #1007
Since: Jun 2006
jimsfield is offline
The SPL using the speaker calibration signal is 23.8 dB, SPL expected was 75dB, check that the AV processor volume, the SPL meter range and the measurement lever are set correctly
What am I doing wrong?
Old 06-17-06, 06:04 PM   #2 (Link)
Alias: jimsfield
Loc: SLC
User: #1007
Since: Jun 2006
Re: Problem setting target level
As I'm checking the set up procedures up to this point I think the Soundcard calibration has not been done correctly. When I try to check the calibration I don't get a flat curve, I get the came curve that was generated initially?
Old 06-17-06, 06:42 PM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
Don't really know what this means?
Do you have the right channel out connected to the right channel in to the soundcard.
Best to also Clear the calibration file with the REW pulldown (even though you don't have one yet). Then stop and restart the program and try again with the soundcard calibration.
Before you tried to set the target level, were you successful with setting the measurement level and then setting the input volume level and then calibrating the spl meter? these of course must be done first.
Old 06-17-06, 09:04 PM   #4 (Link)
Alias: jimsfield
Loc: SLC
User: #1007
Since: Jun 2006
I have right out to right in. Let me try and explain again. When I calibrated theSoundcard I got a curve like it shows in the REW Help with a rolled off bass and a high end with a ripple. I loaded the SC calibration file. Help then describes how to check the that calibration was successful by running Automatic measurement again. When I do that instead of getting a flat line like the red line I get the same curve as the original curve. Is that a better description?
Old 06-17-06, 10:10 PM   #5 (Link)
Alias: brucek
User: #6
brucek is offline
Yep. Hopefully you still have the cable short from input to output still installed and you're using the same (right) channel in the Automatic measurement?
If so, then I can't think of anything that would cause the measurement not to show perfectly flat. You're simply measuring a piece of wire. The soundcards cal file should inversly compensate for its shortcomings and result in a perfect response....
Old 06-18-06, 01:09 PM   #6 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Did you select a channel (tab) other than the soundcard channel? Soundcard cal is not applied to the soundcard channel.
Old 06-18-06, 08:33 PM   #7 (Link)
Alias: jimsfield
Loc: SLC
User: #1007
Since: Jun 2006
I am unable to complete the Soundcard calibration. After I have run Calibrate,
saved the calibration file, the file is loaded, and I go to check the calibration
by running Automatic measurement with the soundcard input connected to the output
I get a dialogue box that says: There are already measurements for this channel,
to continue the measurements must be Removed.
If you Cancel the existing measurements will be kept.
Itappears the calibration file has not been saved or is not loaded. I see the file
in the folder I saved it in. Any ideas?
Old 06-18-06, 09:05 PM   #8 (Link)
Alias: brucek
User: #6
brucek is offline
I guess you called it something like SoundCardCal.cal
When you start REW does it say that this named calibration file is loaded?
If not, when you pull down Soundcard and select Load calibration data, does it say it's loading the file after you point to the file in the location where you store it? Try Clearing and loading and verify that it loads the file.
Old 06-18-06, 10:56 PM   #9 (Link)
Alias: jimsfield
Loc: SLC
User: #1007
Since: Jun 2006
I didn't put the .cal on the end of the file. I think this will get me to the next step. Thanx.
Old 06-19-06, 08:07 AM   #10 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Before checking the calibration click on the "Left" channel tab, otherwise you are just making another measurement on the soundcard channel (hence the warning you are about to overwrite the last measurement you made).
You don't need to add ".cal" on the filename, REW does it for you if you omit it.
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
