Sound out to amp or receiver recommendation - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Sound out to amp or receiver recommendation in the Subwoofer Equalization | Calibration forum; Sound out to amp or receiver recommendation Before I make this cable I want to make sure going from the sound card out directly to the EP2500 ...
Old 11-07-07, 04:11 PM   #1 (Link)
Alias: Warner
User: #4451
Since: Nov 2006
warnerwh is offline
Before I make this cable I want to make sure going from the sound card out directly to the EP2500 is non problematic. I'll turn the volume way down before pink noise is sent out.
The length I make this cable can be 6' or 25'. Thank You
Old 11-07-07, 05:36 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: Sound out to amp or receiver recommendation
It would be better if you fed your receiver rather than your sub amp if you're attempting to do response checks of your subwoofer. Feeding the receiver allows the bass management to be engaged with the crossover....
Old 11-07-07, 07:56 PM   #3 (Link)
Alias: Warner
User: #4451
Since: Nov 2006
warnerwh is offline
Good point. Thank You
Similar Threads
Faulty receiver or power amp? Fincave Home Theater Components 4 11-02-07 04:20 AM
Need help setting up amp and crossover to receiver drwang84 System Setup and Connection 11 10-31-07 08:02 PM
Equalizer & Accurian 5.1 Home Theater Receiver jimlp1 System Setup and Connection 2 06-15-07 11:11 PM
Amp Recommendation southworth DIY Subwoofers 19 05-08-07 07:19 PM
Pre/pro + Amp or all-in-on receiver? haver Home Theater Components 21 07-17-06 11:30 AM
Mach 5 Audio
