| REW Forum REW using Mic inputDiscuss REW using Mic input in the Equalization | Calibration forum; REW using Mic input Good Day everybody,
I am a lucky guy with a company brand new HP V7430EE Laptop. Of course as you ... |
Views: 489 - Replies: 3
| REW using Mic input Good Day everybody, I am a lucky guy with a company brand new HP V7430EE Laptop. Of course as you know that work is much more important than HT stuff....I decided to try REW first I got the soundcrad calibrated as well as the RS cal file loaded an took a sweep. Pls note that the only input that worked is the mic but not the wave mix out. I then did the same with my Desktop (through line in) and I was quite surprized when I compared the results....the very deep stuff is different in SPL. Have a look and suggest pls....but I hope Brucek won't tell me that mic input do not work well with REW ![]() ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #2 | ||||
| Re: REW using Mic input To do a proper comparison, you should test with a loopback cable. If the two machines measure identical, then you will have two straight lines as the response. Connect a cable from output to input of the soundcard, remove the meter cal file, but use the soundcard cal file and do a measurement............ brucek | ||||
| | #3 | ||||
| Re: REW using Mic input Oh Thanks! will do that ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
| | #4 | ||||
| Re: REW using Mic input OOPS! I had assigned the RS cal file to the soundcard.... That's it...Everything should be OK now. Brucek, don't knmow how to thank you enough ![]() ASME AI Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3 Important HT proverbs: - "You can never have too much headroom" (talking about bass) - "you can never have too big a screen" (talking about still pictures) Projector selection basics Epson TW 2000 review | ||||
