| REW Forum REW help PLEASE!Discuss REW help PLEASE! in the Subwoofer Equalization | Calibration forum; REW help PLEASE! After trips all around town I got everything hooked up and I am ready to have a Happy Calibration (Father's) ... |
| | #1 (Link) | |||
| REW help PLEASE! After trips all around town I got everything hooked up and I am ready to have a Happy Calibration (Father's) Day when I get the below error. Please help as Father's Day is only once a year!!! Audio Device Error Unable to access the replay device due to line format PCM-signed 48,000.0Hz, 16 bit, stereo 4 bytes/frame, little-endian not supported. Crap! Thanks for any help available- Greg AVR: Yamaha HTR-5890 DVD: Yamaha DV-C6480 BFD 1124P Mains: Polk RT55 Center: CS300 Sides: RT/FX Rears: RT25i Subs: SVS 20-39 PC+ (12.3 ordered) DIY w/ SVS 12.1 driver HDTV: Panasonic PT-53WX42 -ISF Calibrated IC's: IXOS "Gold" & Gamma spkr wire Power: Panamax MAX 5100 Remote: Pronto Neo | |||
| | #3 (Link) | |||
| Re: REW help PLEASE! Mike, I tried that first, and got the same error message, but with the new sampling rate??? Any other ideas what it could be? It is a Sound Blaster AudioPCI 64V sound card (Win 98SE). Thanks again- Greg AVR: Yamaha HTR-5890 DVD: Yamaha DV-C6480 BFD 1124P Mains: Polk RT55 Center: CS300 Sides: RT/FX Rears: RT25i Subs: SVS 20-39 PC+ (12.3 ordered) DIY w/ SVS 12.1 driver HDTV: Panasonic PT-53WX42 -ISF Calibrated IC's: IXOS "Gold" & Gamma spkr wire Power: Panamax MAX 5100 Remote: Pronto Neo | |||
| | #5 (Link) | |||
| Re: REW help PLEASE! Try using the Creative Device Control program to set the Output Audio Quality to 48kHz, 16 bits and ensure you select 48kHz as the sample rate in REW. If that doesn't help go to the Soundcard menu and use the option to generate a debug file and email that to me, might be some clues in there. | |||
| | #6 (Link) | |||
| Re: REW help PLEASE! Thanks John; I appreciate your help! I'm very frustrated. I can't find a Creative Control Device and not sure where to find the debug file. The only setting I could find was for "Optimal", which I set to the highest level. Before I started this project, I actually thought I knew quite a bit about computers, now I feel like a dufus. I'm wondering if this computer isn't just too old (Win 98SE)? Maybe I'll switch it out with the XP computer from my office, but it has an integrated soundcard. Will that still work? Thanks again- Greg AVR: Yamaha HTR-5890 DVD: Yamaha DV-C6480 BFD 1124P Mains: Polk RT55 Center: CS300 Sides: RT/FX Rears: RT25i Subs: SVS 20-39 PC+ (12.3 ordered) DIY w/ SVS 12.1 driver HDTV: Panasonic PT-53WX42 -ISF Calibrated IC's: IXOS "Gold" & Gamma spkr wire Power: Panamax MAX 5100 Remote: Pronto Neo | |||
| | #7 (Link) | |||
| Re: REW help PLEASE! A PC with integrated soundcard should work fine. The debug file is something you generate from within REW, the option to generate it is in the REW Soundcard menu. I'd be interested to see it even if you decide to switch to the XP PC. Where did you find the "Optimal" setting you refer to? | |||
| | #8 (Link) | |||
| Re: REW help PLEASE! John, Here is the file. Please let me know if it is correct. I would really like to get this computer working for REW if possible. Thanks for your help! Regards- Greg AVR: Yamaha HTR-5890 DVD: Yamaha DV-C6480 BFD 1124P Mains: Polk RT55 Center: CS300 Sides: RT/FX Rears: RT25i Subs: SVS 20-39 PC+ (12.3 ordered) DIY w/ SVS 12.1 driver HDTV: Panasonic PT-53WX42 -ISF Calibrated IC's: IXOS "Gold" & Gamma spkr wire Power: Panamax MAX 5100 Remote: Pronto Neo | |||
| | #9 (Link) | |||
| Re: REW help PLEASE! Are you running any other application that uses audio input and/or output? It looks from the debug file as if some app has taken exclusive control of the soundcard so when another app (such as REW) asks for an input or output the request is refused. | |||
| | #10 (Link) | |||
| Re: REW help PLEASE! John, The only thing I can think of is my MIDI adapter (below). It has been acting weird ever since I loaded it. Each time I boot up it asked for the drivers even though I have previously successfully loaded them? http://www.m-audio.com/products/en_us/Uno-main.html AVR: Yamaha HTR-5890 DVD: Yamaha DV-C6480 BFD 1124P Mains: Polk RT55 Center: CS300 Sides: RT/FX Rears: RT25i Subs: SVS 20-39 PC+ (12.3 ordered) DIY w/ SVS 12.1 driver HDTV: Panasonic PT-53WX42 -ISF Calibrated IC's: IXOS "Gold" & Gamma spkr wire Power: Panamax MAX 5100 Remote: Pronto Neo | |||
| | #11 (Link) | |||
| Re: REW help PLEASE! Hi, I just wanted to test my room eq.I set up REW.It plays back only through the java sound engine.If I select the internal Creative Vibra 128,I get the same message Unable to access the selected device due to line with format PCM_SIGNED 44100.0 Hz,16 bit stereo,4 bytes/frame,little-endian not supported Also I am unable to select any device for input. I am using win98 and creative vibra 128. I have also attached the debug file. Any help ? ![]() | |||
| | #12 (Link) | ||||
| Re: REW help PLEASE! Quote:
LineIn.jpg What are you selecting for the wave control device as shown below? LineInSelect.jpg brucek | ||||
| | #13 (Link) | |||
| Re: REW help PLEASE! I Can see my soundcard in Choose device option,but the Choose Input option is greyed out.http://www.hometheatershack.com/foru...1&d=1155541468 Selection for the wave control device i have tried both with the Line in option as well as the Use Default (Wave) option http://www.hometheatershack.com/foru...1&d=1155541468 The Debug file http://www.hometheatershack.com/foru...1&d=1155541468 ![]() | |||
| | #14 (Link) | ||||
| | #15 (Link) | |||
| Re: REW help PLEASE! Hi, No luck even if I try to change settings to 48KHz. I could not find any settings to change the sample rate of the sound card. I also tried to use the onboard Realtek AC97,but face the same problems. Maybe I'll have to wait for a newer version of REW or arrange for an external USB soundcard. Anyway thanks to all who replied. ![]() | |||
| | #17 (Link) | |||
| Re: REW help PLEASE! I don't mean to speak for him, but John has been out of the country quite a bit lately on business and so this slows down the process, but he threatens to release the beta for testing fairly soon. I guess you'll just have to be patient............. brucek | |||
