First Measurement - Starting point for a work already in progress - Page 2 - Home Theater Forum and Systems - HomeTheaterShack.com
post #11 of 34 Old 02-08-14, 01:42 PM Thread Starter
Austin
Re: First Measurement - Starting point for a work already in progress
Yes the first row is dead center in the front of the room.I have made a bunch of sweeps this morning. Including this graph below. I moved one sub to the side in the front of the room and the second sub to the corresponding rear corner. Much smoother response. Your thoughts?
First Measurement - Starting point for a work already in progress-feb-8-front-rear.jpg
Feb 8 front rear.mdat
Still not exactly digging very deep......?
AGINHOUSE is offline
post #12 of 34 Old 02-08-14, 01:46 PM
tonyvdb's Avatar
Tony
Sadly having the main listening position in the centre of the room makes it very difficult to get good results as that is where all of the reflections converge causing nulls and cancelation. Moving the subs around can help somewhat but treatment of the walls is the only real solution or move the front row back a few feet and get rid of or move the rear seating all the way back if it is not already.
Home theater:
Living room system:
tonyvdb is offline
post #13 of 34 Old 02-08-14, 01:53 PM Thread Starter
Austin
I am sorry, I forgot to mention that I took a measurement in the back row. It was center line though. I will try again with the microphone off to one side.
post #14 of 34 Old 02-08-14, 03:52 PM
Use the RTA in REW for each at a time, and move the mic around to see if extension/response improves.
What is the specs of the subs?
Have you tried the phase?
What size drivers are the subs?
Phillips is offline
post #15 of 34 Old 02-08-14, 04:45 PM Thread Starter
Austin
Phillips, I tried the phase last night and switched to 180 and it just made the response quieter.
The drivers are 12". Here are the specs.
FREQUENCY RESPONSE: 26Hz-120Hz 3dB
MAX ACOUSTIC OUTPUT: 116dB @ 30Hz
AMPLIFIER: BASH Digital Hybrid
AMPLIFIER POWER: FTC Rated Power: 300 watts continuous @ <2% THD / Dynamic Power*: 600 watts
DRIVE COMPONENTS: 12" (30.5cm) Active non-resonant Woven Fiberglass driver
ENCLOSURE TYPE: Bass-reflex via front-firing slot port
INPUTS: L/R Line-level RCA jacks, L/R High-level speaker binding posts, WA port
OUTPUTS: None
HEIGHT: 16" (40.6cm)
WIDTH: 14.5" (36.8cm)
DEPTH: 19" (48.3cm)
WEIGHT: 46lbs (20.9kg)
FINISHES: Black pica
VOLTAGE: 100-120V / 220-240V~50/60Hz 3.15A (Auto-voltage switching) with 1 Watt standby
post #16 of 34 Old 02-08-14, 08:18 PM
HTS Senior Moderator
Wayne A. Pflughaupt's Avatar
AGINHOUSE wrote: View Post
For sure. Did you by chance take separate measurements? That might be instructive.
post #17 of 34 Old 02-09-14, 12:15 AM
Please do this
With these specs with 2 26hz should be easy.
Ok if you did this with one at a time leave at 0 degrees
What do the mains measure, matter of interest?
Phillips is offline
post #18 of 34 Old 02-09-14, 12:27 AM
It sounds like you have the two subs more-or-less centered on the front wall? If so, move them to a corner. If you have a symmetrical room, you can put one in each front corner. If your room is asymmetrical, it would be best to stack them in the corner that has the longest uninterrupted length of wall (i.e., no openings). His should improve your extension significantly.
Sorry Wayne to jump in here.
Have you tried this what Wayne has suggested?
Try moving the mains in, then put the subs on the outside of the mains (corner loading).
Generally speaking use the 3rd rule for starters.
Measuring one at a time is your best starter, RTA is a quick way to measure for positioning for sub/s etc and listening position, then fine tune with the sweep (normal measurement).
Phillips is offline
post #19 of 34 Old 02-09-14, 10:45 AM Thread Starter
Austin
Good morning guys, I apologize for the delayed response.
Yes Wayne, I took quite a few measurements. Here are a few.
First Measurement - Starting point for a work already in progress-feb-8-pos3-stkd.jpg
Feb 8 pos3 stkd.mdat This is the subs stacked along the longest uninterrupted wall
First Measurement - Starting point for a work already in progress-feb-8-stacked-front.jpg
Feb 8 stacked front.mdat This is the subs stacked on the front wall one third of the way across
First Measurement - Starting point for a work already in progress-feb-8-pos2-phase0.jpg
Feb 8 pos2 phase0.mdat This is the subs split apart. One on each side equal widths apart.
Im sorry Phillips, Im unable to corner load the sub in the front of the room because that would relocate my towers to be in front of the projection screen.
Im don't follow regarding your instructions regarding RTA. Is there somewhere I can read about this? If so I'll try to study up and analyze for you based on my room.
I hate to be waisting everyone's time here but, Im beginning to feel as though Im just doing something wrong? Could it be my calibration file? I have verified the spl levels in REW with my SPL meter.....?
calibration1381251.txt
Phillips, would you like me to turn my sub off and take a bass sweep with my mains? or do you want subs and mains together in a bass sweep?
post #20 of 34 Old 02-09-14, 11:50 AM
REW Author
JohnM's Avatar
John
The feb 8 pos 3 stkd and feb 8 stacked front measurements are not valid, if you look at the impulse responses you will see two peaks about 1.1 seconds apart, perhaps some strange buffering behaviour in line in/soundflower/OS X/Java. Best to keep an eye on the impulse response after each measurement and discard any that look like those.
JohnM is offline
measurement , point , progress , starting , work
