| REW Forum Using convolver universally in HTPCDiscuss Using convolver universally in HTPC in the Equalization | Calibration forum; Using convolver universally in HTPC Thanks a lot for your help. After all I think also, that the most important thing is to build a ... |
Views: 8615 - Replies: 133
| | #101 | ||||
| Re: Using convolver universally in HTPC Thanks a lot for your help. After all I think also, that the most important thing is to build a correct impulse response. So I will try out REW to build the impulse response and will give a feedback about the result. | ||||
| | #102 | ||||
| Re: Using convolver universally in HTPC Antani, now I am back. I have tried out REW. I can make the measure. After this I go to menu "file->export->export->Impulse Response as WAV..." The exported file ImpulseResponse.wav has to be the BCInFile in DRC, right? The result (the filter) however looks not o.k. Did I make something wrong? I guess the BCInFile has to be in PCM (raw) format. But in RWE I can export the Impulse Response only in WAV-Format. Do I have to convert the exported file first, an if yes how ist the sox-script for this? | ||||
| | #104 | ||||
| Re: Using convolver universally in HTPC Hi. I have a config file for 44100 and another for 48000, how can I make a config file for switch automatically between filters?. Here http://convolver.sourceforge.net/config.html says that can switch automatically but I don't know how. Thanks. | ||||
| | #105 | |||||
| Re: Using convolver universally in HTPC Quote:
| | #106 | ||||
| Re: Using convolver universally in HTPC I don't use Convolver so I'm not really sure. However from what I understand, you should create multiple settings in the config.txt file, simply putting them one after the other, in different rows. Convolver should choose automatically the appropriate settings from the sample rate of the file being played. From the Convolver help: So a config file can also comprise of a list of - filter specification config file names of the type described above; and - WAV impulse response filenames one per line. The filter used will then be the first to match the current sound source (in terms of number of input and output channels and sample rate). This allows you to play both stereo and 5.1 sources, say, without having to change the config file. | ||||
| | #107 | ||||||
| Re: Using convolver universally in HTPC Hi, thanks. Quote:
well, I try to make one config file with both but I cann't find the way, one after the other or in different rows... nothing. Thanks. | ||||||
| | #108 | ||||
| Re: Using convolver universally in HTPC The syntax of Convolver isn't really user friendly . I also remember that some people had problems with the format of the config file (that should be Unicode or ANSI, I'm not sure). | ||||
| | #110 | |||||
| | #111 | ||||
| Re: Using convolver universally in HTPC No need for that. Just select 8 sweeps in the Measure window. By the way I think there is a little bug in the sw, because I often get weird results. I always check the coherence with a single short sweep, and the scope window as well (sometimes clipping is not signaled). | ||||
| | #112 | |||||
This post (to the end) is a perfect example, where in the end, the problem is computer related. brucek | |||||
| | #113 | ||||
| Re: Using convolver universally in HTPC It is definitively possible, I didn't test very much. However I got problems only with multiple sweeps. I guess the multiple sweeps option is seldom used, but it is very useful when maximum resolution is needed, like for DRC. | ||||
| | #114 | |||||
brucek | |||||
| | #115 | |||||
Also, I am using console with the optimized.drc coefficients loaded in Voxengo PristineSpace. When I test the room correction filter by sweeping REW through PristineSpace in console, REW is complaining that the impulse response peak is not where it is supposed to be. Looking at the PristineSpace window, I find that the filter center tap is at the middle of the window (latency of N/2 samples). Is this the reason REW is saying this? Thanks. brucek, Even with two sweeps, I am getting a wierd comb like transfer function with the first null at 1.75KHz. I can try to post the plots after I get back home. | |||||
| | #116 | |||||
brucek | |||||
| | #118 | |||||
brucek | |||||
| | #119 | ||||
| Re: Using convolver universally in HTPC antani, brucek: Thanks to antani's tip of looking at the scope window, whenever I use a multiple sweep option in the measurement, I am seeing wierd looking input samples, only in the second sweep (figure below). I dont see this behavior in the first sweep. Whenever this happens, the transfer function has the combing artifact. Is this my setup issue or is it something else? Thanks. | ||||
| | #120 | ||||
| Re: Using convolver universally in HTPC The input is the dark red line and the output samples are the purple. Looking at the time axis, I would presume you're examining a fairly high frequency. You can expand the axis and look at each sample. You'll probably find that the 'sinusoidal' wave is distorted at this higher frequency. I know on my inexpensive soundcard, that the DAC probably isn't the greatest, and regardless of whether I use more than one sweep, I'll have a fairly poor looking output signal at the upper frequencies. Certainly at 20K, with a 44KHz sample rate, there's only a couple samples per period and it looks pretty bad. I'm not sure why you would only see the output problems on multiple sweeps though. I'll ask JohnM what he thinks.. brucek | ||||
| | #121 | ||||
| Re: Using convolver universally in HTPC This comb effect is pretty strange. I normally check the multiple sweeps result with a single short sweep. If the frequency response is very similar, the measurement is supposed to be ok. In the scope window I just check the clipping. I often get problems with 8 sweeps, rarely with 4 sweeps, so it is possible that the issue is lack of memory as Brucek was suggesting. The warning "response peak is not where it is supposed to be" is normal if you use a linear phase FIR filter. In fact the linear phase filter adds a delay of 0,7 s, but this shouldn’t cause any problem. BTW you don't really need to use a linear phase FIR, unless you are using a brickwall filter. | ||||
| | #122 | |||||
| | #123 | ||||
| Re: Using convolver universally in HTPC JohnM, Thanks for the explanation. I will try the sweeps from a different PC and see if this persists. If the problem persists, I will try to up the RAM on the regular PC. Thanks again! | ||||
| | #124 | |||||
| | #125 | ||||
| Re: Using convolver universally in HTPC Thx for a great thread with spot on information for my use. Im struggeling a bit with console, could anyone be so kind as to how they set up the routing for the various modules? I assume one just add console as an external filter in Media Player Classic to have the sound pass through the plugins hosted by console. Im trying to have a simple 2-channel signal passed through convolver and the Kelly Industries Bass Manager for a start. Last edited by nbb; 07-16-09 at 04:41 PM.. | ||||
