REW Forum
Zen and the art of REW - Help!
Discuss Zen and the art of REW - Help! in the Equalization | Calibration forum; Zen and the art of REW - Help! To cut a long story short, I have just purchased a FBQ2496 and I have spent my first evening with ...
Views: 524 - Replies: 6
Old 11-13-07, 03:29 PM   #1
benbigdude
Inactive
Alias:
User: #
Posts: n/a
To cut a long story short, I have just purchased a FBQ2496 and I have spent my first evening with it and REW. The results are below...I would really appreciate your feedback....are these any good?
These are sub only...
Graph 1 - No filters
Graph 2 - 9 filters applied
Thank you
Old 11-13-07, 03:47 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: Zen and the art of REW - Help!
Well, you haven't told us a lot about your sub, but when plotting the results it's best to stick with the standard of using a vertical scale of 45dB-105dBSPL and a horizontal axis of 15Hz-200Hz.
I'll also add that there is a nice feature in REW that sorts your filters from low to high. Click the little up/down arrows in REW Filters screen for that.
You've added four filters above 100Hz that are likely not needed. The level from the sub is down considerable above 100Hz and so the when the mains are added, the effect of the filters in the sub at those upper ferquency will not matter. You can likely eliminate them.
You don't show any filters at 25Hz, yet I note the level has been increased at that frequency quite a bit. Can you discuss how much gain you added in your filters. Large gains are somewhat frowned upon.
I don't feel you've eliminated the peak centered at ~35Hz quite enough.
Old 11-13-07, 03:47 PM   #3
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
Of course, the graph looks better with the equalizer, but I am quite positive you could propably do better with some more tweeking. In the Filter tasks did you follow the sequence:
- Find peaks
- assign filter
- Optimize PK gain & Q?
I think it would be worth trying.
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 11-13-07, 04:08 PM   #4
benbigdude
Inactive
Alias:
User: #
Posts: n/a
Sorry for the axis formating - Believe it or not I read the formating post...must have just got excited!
The sub is a REL Q201e, my processor is a Rotel RSP-1068. I am using the external USB Sound Blaster card and a RadioShack analogue SPL.
The filters I have set are:
Thank you
- Find peaks
- assign filter
Yes - I followed these steps.
Old 11-13-07, 05:02 PM   #5
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
OK...Try one thing: restart from scratch but lower the target setting to be 70 db instead of 75 db. I think you will get a flatter graph.
ASME AI
Old 11-13-07, 09:40 PM   #6
Alias: Wayne
Wayne A. Pflughaupt's Avatar
Loc: Katy, Texas
User: #8
Five of your filters are above the subwoofer range and are not needed. Limit the “Find Peaks” option to find peaks only below your crossover point
Not sure I would lower the target curve. It’s just going to cause REW to generate superfluous filters.
Old 11-14-07, 04:45 AM   #7
benbigdude
Inactive
Alias:
User: #
Posts: n/a
Thank you for all the responses....I will try them out over the next few days and report back.
