REW Forum
bfd and rew question
Discuss bfd and rew question in the Equalization | Calibration forum; bfd and rew question I have a strange thing happening. I set up rew and the bfd and did some measurments and just tried ...
Views: 435 - Replies: 1
Old 11-15-07, 03:28 PM   #1
mrsnapper
Inactive
Alias:
User: #
Posts: n/a
I have a strange thing happening. I set up rew and the bfd and did some measurments and just tried to get familiar with the tools. Things seemed to be working out. Then I wanted to experiment and this is what I did. I took the bfd out of the loop. I wanted to start by using my avr's audyssey program as a start and use rew to see what it's doing. It didnt look to bad actually. Then I was going to fine tune with the bfd. So I put the bfd back in and pressed the in/out button(flashing) and assumed I was in bypass mode, straight in-out. I then took another measurement to see if my graphs changed and they did, a lot. But no filters are being applied. Why would this be? My gain messed up maybe, or maybe I didnt calibrate the sound card correctly?
Another odd thing is when I do a measurement and get a graph and then generate a waterfall of it the peaks on each are different? They look similar but the peaks line up at different freq.
Souncard- rme ff800
avr-onkyo 805
bfd 1124p
rs digital spl meter
ecm8000
Old 11-15-07, 03:57 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: bfd and rew question
I wanted to start by using my avr's audyssey program as a start and use rew to see what it's doing...................Then I was going to fine tune with the bfd
Yep, many people with auto eq do this...
Green LED on=filters engaged.
Green LED off=filters disengaged.
Green LED flashing=Filters disengaged, with VU meters displaying input level rather than output level.
With the in/out LED flashing or off, the BFD offers unity gain. There would be no modification to the signal or its level....
Move the slider to a single slice of 1. It will be the same as the frequency response graph. The peaks will line up exactly the same..
