Hello,
I have purchased and used R+D to tune my system and am very happy with the results. Thought I would give REW a test drive to see just how close the two programs are compared. The thing is I purchased the USB sound card that Acoustisoft rec. and sells, which works fine, but I don't know if I can use this soundcard with REW or not. I combines the "input and output" of the left channel internally in the soundcard box. And you just use the right channel for measurement, which is great not to have all these cables running everywhere. But if I wanted to use this soundcard with REW and my laptop, would'nt I have to disconect the "left input to output connection". I think REW just uses one channel of the soundcard, once to create a calibration file, and then the same channel becomes your measurement channel, right? Using R+D it leaves the left channel connected in the loop through configuration so it measures the soundcard each time you run a measurement. Can I still use this soundcard with REW?, even though the left channel will stay looped?:scratch:
Thanks,
Vince
Thanks,
Vince
