| Am I on the right track here? Recently I decided it was time add a sub to my system. Fortunately I stumbled on REW at about the same time. I ordered a Hsu VTF-3 MK2, and while I was waiting for it to arrive I took the time to learn REW. Once I figured it out it works wonderfully on my notebook with my M-Audio Firewire Audiophile. I measured the Mains, then cringed at the graph for a while, but such is life. I did learn that where I have my main speakers located the frequency response dropped off rapidly below 80hz, so a sub=good idea. I also took my computer sub (Klipsch SWS) and tried it in various places to find some possible locations for the VTF3.
Now I will take a minute to explain my room here… It is very large. 5000+ cubic feet thanks to the lovely open floor plan of the house. It is (relative to the location of system) 16’ long, 26 wide, and with the ceiling starting at 12’ at the front and sloping down to 8’ in the back. This is open to the kitchen area, and the front entrance.
When the new sub arrived, I decided to try it in a back corner first. Way too easily localized. 80hz is the lowest crossover setting I get on my Panny xr 55. It’s great otherwise but it has a severe lack of bass management. For me to not be able to localize the sub, it has to be directly behind me, which works quite well practically.
It sounded great with the exception that to even be able to perceive any lower bass, below 40hz, I have to set the volume much higher than balanced. The graphs from REW (which I don’t have otherwise I’d post… I guess ‘Ill have to make some more and save these) show that it get a fairly jumpy but at least in the same general area as the target response down to a huge peak at around 50hz. After this however it drops about 10 to 12 db and stays very flat down to about 15hz or so. The graph resembles a staircase.
I’m wondering what the best solution to this would be. 2 parametric filters would bring the mid bass down to level of the rest, and I could turn up the subs volume. I would just buy a BFD, but thankfully I discovered before I did that my receiver doesn’t have a distance setting for the sub, so I can’t compensate for its delay. I’m looking at the Rane PE 17 since its all analog with no delay. Its expensive, but I’m certainly not getting my moneys worth out of the sub as it is.
That’s my current plan. Anything I’m missing or overlooking here?
Again, I’m very impressed with REW, as it has made most of this possible or at least much easier. |
