Question on proper volume levels for testing - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Question on proper volume levels for testing in the Subwoofer Equalization | Calibration forum; Question on proper volume levels for testing I apologize if this has been asked, but I searched all over and I appear to be the only dumb ...
Old 12-20-07, 06:38 PM   #1 (Link)
Alias: Corey
Loc: Los Angeles, CA
User: #14470
Since: Dec 2007
ckaye99 is offline
I apologize if this has been asked, but I searched all over and I appear to be the only dumb one with this question:
My sub is connected to my BFD, which is connected to my receiver. When I use REW, I connect the soundcard to the BFD, and remove the connection to the recevier (unless I'm mistaken already). When I do the setup for the REW, i.e. levels, calibration, etc., how high should the volume knob be on my sub?
Or am I missing the point? Should it be set to whatever it needs to be so that the Radio Shack meter reads 75db?
Assuming then that I finally manage to EQ the sub (if I can get the above questions resolved), when I go to re-integrate it with the rest of my system, which device do I plug the external sound card into at this point to run a sweep to say 200hz (or higher?) to see how the sub matches with the other speakers (I'm guessing the receiver at this point)? And what volume level should I run these tests at?
I feel like I may be making a lot out of a nothing issue, but for some reason I'm having a mental block on these items. Thank you in advance for any advice.
Old 12-20-07, 07:27 PM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Re: Question on proper volume levels for testing
Hi there,
The sound card should go into the receiver's analog inputs. So it goes like this:
Soundcard->Receiver->BFD->Sub
I'd suggest starting with the sub volume somewhere in the middle, and then adjusting the receiver volume till you get 75 dB. Then go from there.
Good luck
-- Otto
Old 12-20-07, 07:52 PM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
As Otto says, connect it like this..........
Old 12-21-07, 01:10 PM   #4 (Link)
Alias: Corey
User: #14470
Since: Dec 2007
ckaye99 is offline
I'm an idiot, completely overlooked that drawing even though I saw it previously.
Similar Threads
HD channel volume vs. analog channel volume Mongrel714 General Discussion 11 04-09-08 10:14 AM
Seats that place head in proper viewing Position? Scuba Diver Home Theater Seating and Accessories 5 10-29-07 12:14 AM
Volume versus effective volume? ramchip007 DIY Subwoofers 4 08-29-07 01:57 PM
Setting Levels in SW Anthony DIY Speakers 2 07-17-07 08:19 AM
proper upload format scott General Discussion 1 01-10-07 09:33 PM
Mach 5 Audio
