method to identify room modes - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
Discuss method to identify room modes in the Subwoofer Equalization | Calibration forum; method to identify room modes Hi all...been reading & researching for a year & a half now, and just recently finished the basement so I've ...
Old 12-18-07, 01:39 PM   #1 (Link)
New Member
Alias: Huguetguy
Loc: Richmond, VA
User: #484
huguetguy is offline
Hi all...been reading & researching for a year & a half now, and just recently finished the basement so I've started calibrating my subs...i'm in the process of trying to identify my room modes so that I can place the subwoofers in best locations for minimal eq necessary with the BFD and to eliminate nulls at the seating positions...
this is my room layout (home theater/media room in lower left, or south west corner):
The media room is closed off from the rest of the basement, with framed drywall walls all around. the south and west walls have concrete block behind the framed walls, the walls are all filled with insulation. concrete floor with carpet.
I've run the spreadsheets to identify what room modes I theoretically should encounter, and had some ideas to combat those modes with 2 svs 25-31 pci's...but what I'm finding is that some modes are showing up, and some aren't, and some are coming out of nowhere...
These are the predicted room axial modes:
And this is the process I've followed so far, please correct me if I'm misunderstanding something...
1. Put 1 subwoofer in southeast corner, put spl meter close to floor in north east corner (near 2 closed doors)
2. Ran 15-200 hz sweep with REW
I see easily recognizable 19, 38, 57, and 77 hz modes/peaks for sure…but the puzzling thing is that there’s a 31-32 hz NULL in the corner…and it seems to remain in other measurements also when I move the mike out to seating positions too…
I will try to post REW graphs soon, but for now wanted to see if I’m doing something wrong, or if I’m misguided…how can you get a null in a corner? That’s my main question right now…
Old 12-18-07, 02:20 PM   #2 (Link)
Alias: Maverick
Loc: Sandnes, Norway
User: #7168
Since: Mar 2007
atledreier is offline
Re: method to identify room modes
Images don't show for me...
Old 12-18-07, 02:33 PM   #3 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
I don't see the images you posted.
It's important to remember that you may have to move your subs from the corners if you want to get the best frequency response. Corners increase bass but may nor fit your room/setup.
Did you try to change the phase on your subs in order to correct the NULL areas ?
Also, you should only be interested in measuring around your sweet spot. Will you seat in the north east corner ?
Another trick may be to test with open/closed doors. You may be surprised to see how much difference a door can make ......
Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100"
Old 12-18-07, 03:52 PM   #4 (Link)
New Member
Alias: Huguetguy
Loc: Richmond, VA
User: #484
jerome wrote: View Post
I realize all that...I don't plan on leaving them in the corners...it's just to start, I put one in the corner and ran it by itself to find out what the room modes are, and am running into this weird null...
if I can figure out the room modes, I can calculate locations that will neutralize the modes/nulls, and then put the mic in the seating areas and tweak from there...
just wanted to see if anyone knows how you can get nulls in a corner...
Old 12-19-07, 07:09 AM   #5 (Link)
New Member
Alias: Huguetguy
Loc: Richmond, VA
User: #484
Here is my graph of the corners measurement...
I ran this with REW & the sub calibrated to 80 hz baseline, using the REW pink noise output.
to me, it sure looks like the axial length 19, 38 & 57 hz modes are all showing, along with the axial width 44 hz mode. But what are the sharp valleys in there - they sure look like nulls to me, around 56, 77 (shouldn't that be a peak instead, from the axial length modes?!).
Is it possible to get nulls in a corner? Do you think that's what those are, those sharp valleys, or are those just what it's supposed to be at, and the modes are so pronounced that the parts in between appear to be valleys...
Based on these mode measurements, I had wanted to put the subs at the 1/3 & 2/3 positions along the length wall, based on a suggestion from Ed Mullen, but when I did that and mic'ed the corner again, it didn't really eliminate the 19 hz bulge, and I still got a 31-32hz null, coming out of nowhere...will have to redo that measurement and post the graph to show you.
Old 12-19-07, 08:32 AM   #6 (Link)
Alias: Maverick
User: #7168
Since: Mar 2007
you still have floor and ceiling nulls, at the very least.
Old 12-19-07, 09:05 AM   #7 (Link)
New Member
Alias: Huguetguy
Loc: Richmond, VA
User: #484
but would I get those with the mic at the floor, in the corner? I mean, I know there's a 1st harmonic null halfway up in the air, and then a 2nd harmonic at the 1/3 & 2/3 heights...but aren't the strong modes located always in the corners, closest to the room boundaries?
Old 12-19-07, 07:34 PM   #8 (Link)
Alias: Edward
Loc: Brampton ON, Canada
User: #8188
Since: Apr 2007
clubfoot is offline
You have to remember that the predicted modes are for an ideal rectangular room, from your sketch your room isn't square in one corner! Looks like a corner fireplace?!
Forget about the modes for now, just place your mic in you seating location and take a measurement of your sub only and see if it tracks the target curve.
Old 12-19-07, 08:53 PM   #9 (Link)
New Member
Alias: Huguetguy
Loc: Richmond, VA
User: #484
yup, it's a corner fireplace. how does that affect modes?
i know, i know, i could skip all this and go straight to testing my 6 seating positions...but the problem with that is that I wouldn't have solidified my understand of room modes and how sub placement affects them. I am trying to confirm whether placing a mic in the corner will work to show what room modes are excited for each sub location that I test. I guess I'd like someone who understands the scientifc theory to confirm or deny that for me...
I'll get to the seating locations in a bit, but first I want to understand the room interactions at their most basic level before getting into seating locations (because the couch can be adjusted, and the subs can be moved depending on what I find).
Old 12-19-07, 10:18 PM   #10 (Link)
Alias: Edward
User: #8188
Since: Apr 2007
clubfoot is offline
The accuracy of the predicted room modes is based on rectangular room dimensions, once the room deviates from a rectangular shape out goes the accuracy! It takes allot more math for oddly shaped rooms, which is why I suggested going straight for the seating location
Old 12-21-07, 09:30 PM   #11 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Is that with both subs in the two corners? That’s some pretty weird-looking response. Almost looks like some kind of comb filter happening. Have you tried taking a reading of each separately. It would help for comparison’s sake. As brucek eloquently put it in a recent thread, the only real reason to separate subs would be to achieve a combined response that you can’t get from each separately.
Old 12-22-07, 09:08 PM   #12 (Link)
New Member
Alias: Huguetguy
Loc: Richmond, VA
User: #484
that was with 1 sub in the southeast corner, and the mic in the north east corner. I have lots of graphs now, I will post something later maybe wednesday after christmas...it's quite frustrating trying to achieve flat response over 8 seating positions...there's so many possible sub locations & phase combinations that it's mind boggling...just trial & error at this point...
more to come later...
Old 12-23-07, 04:11 AM   #13 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
huguetguy wrote: View Post
As I have experienced, it's not an easy task to achieve a satisfying response curve over 8 seats. Usually, you will have to decide what is the most important seating area (typically your sweetspot) and try to compromise for the other seats.
As for the best way to achieve a good calibration, the try & error method works. For a given sub position, you will quickly find what is the best phase/delay adjustment using real-time measurements in REW.
In my opinion, it's a very difficult task (if not impossible) to find the best theoretical location and phase in most rooms. You always have furniture, windows, doors, a non-rectangular room, ... that will make the theory fade away. I know how it feel sometimes: Your current curve is not looking good at all but you should only focus on the seating positions, not the corners.
Good luck !
Old 12-30-07, 07:20 PM   #14 (Link)
New Member
Alias: Huguetguy
Loc: Richmond, VA
User: #484
Well I have found 2 locations that seem to give pretty good response over the 8 seats. I'm putting one sub along the bottom wall, in the middle. The other sub is going along the east wall, about 38" off the corner.
I have measured, and remeasured...I loved the response I was getting with both subs by themselves, but when I added in the main speakers, it threw things off a little...so I adjusted them slightly...
This is what I'm getting now, pre BFD. The charts will start at the leftmost seat on the couch, and go right. 8 seats total...
Left 4th seat out:
left 3rd seat out:
left 2nd seat out:
left middle seat:
right middle seat:
right 2nd seat out:
right 3rd seat out:
right 4th seat out:
Can you guess which seat I'll be sitting in?
Next I'll guess I'll measure each sub separately at all seating locations, try my hand at some filters on each sub, and then remeasure together.
Oh, another thing. The eastmost sub is set at 130 degrees phase while the one in the middle is set at 0 degrees phase. the couch is pulled 13" off the wall.
Old 12-30-07, 07:43 PM   #15 (Link)
New Member
Alias: Huguetguy
Loc: Richmond, VA
User: #484
here's a graph showing specific null frequencies I found when I had just 1 sub in the corner, measuring along the length of the room (the longest dimension)...they occur at specific locations that just happened to be in bad seating locations.
here are the height nulls I found, when the sub was on the floor, and the mic was at 51, 57, and 58" from the ceiling.
the width nulls didn't really line up with the theoretical predicted nulls at locations expected, these occured at 96 & 99" from the south wall, along the east wall. the sub was at the southeast corner.
I tried putting the subs at the 1/3 & 2/3 locations along the length at first, it didn't seem to help much. Then I tried a sub in the corner and one in the middle of the length to combat the huge 19 hz hump. Then I tried one in the middle of the east wall, and the other middle of the bottom...didn't like that.
I might also try 1 sub at 96/99" along the east wall, and the other in the middle of the length to see if that gives even flatter response...I had to pull the east sub away from the corner, and the couch away from the wall or there was a major hump around 44 hz...
It's really hard to explain all the different combinations that I've measured, but I thought I'd try to explain a little in case others were wondering...
Similar Threads
Best listening modes for someone with a 5.1 setup? lovingdvd Home Theater Components 9 11-14-07 08:30 PM
Who knows about low frequency room modes? tdamocles REW Forum 4 02-27-07 07:14 PM
Calculating Room Modes - Odd Shaped Room Bob in St. Louis Home Theater Design and Construction 25 02-20-07 12:15 PM
Zu Method or Mini Method rean1mator Home Audio Subwoofers 0 02-07-07 02:28 PM
Alternative Bass EQ Method bellnm BFD Forum 4 10-25-06 02:21 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
