First measurements - with bass traps+eq - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss First measurements - with bass traps+eq in the Subwoofer Equalization | Calibration forum; First measurements - with bass traps+eq Left chair, no EQ Left chair, with EQ Right chair, no EQ Right chair, with EQ Back row, middle-left (eq'd) ...
Old 01-02-08, 07:22 PM   #1 (Link)
Alias: Jesse S
Loc: Toronto, On
User: #1701
Jman is offline
Left chair, no EQ
Left chair, with EQ
Right chair, no EQ
Back row, middle-right (eq'd)
The back row packs a wallop. I listened to Flight of the Phoenix here. When the plane rolls it hits something like 125db and feels like the air is being sucked out of the room. One of the few times that actually felt a little too loud.
Left chair with EQ (same as above)
Left chair with EQ but the rear left bass trap removed
Note how just removing 1 bass trap immediately causes a significant
notch to appear in the 95hz region.
The left chair is my favorite seat so that's what I eq'd. The right chair has pretty similar response so the eq isn't too far off. Maybe I'll try an average curve and eq to that. The IB sub's deep extension is fairly obvious
Jesse S.
Old 01-03-08, 12:22 AM   #2 (Link)
Alias: Jerome
Loc: Norway
jerome's Avatar
User: #8468
Since: Apr 2007
jerome is offline
Re: First measurements - with bass traps+eq
Hum, interesting! What kind of bass trap did you remove?
Did you try to measure sub+main too? I think that your main speakers should take over at 95Hz and you may not be able to see any differences when removing your bass trap
You have probably seen it but removing your bass trap gives you higher levels around 150Hz too ...
Martin Logan Vista | Swans F1.1C | SVS PC-Ultra | SlimDevices Transporter | Bladelius Tyr | Yamaha RX-V1800 | Denon DVD-2930 | Klipsch RS-52 | Sharp XV-Z3000 | Adeo Greyvision Plano 16:9 100"
Similar Threads
Bass traps Fincave Home Audio Acoustics 55 06-01-08 09:00 AM
Sonotube bass traps? Prozakk Home Audio Acoustics 3 12-07-07 08:11 PM
New bass traps greatmane Home Audio Acoustics 2 11-08-07 12:23 PM
Bass traps or EQ F1 fan Home Audio Acoustics 78 04-26-07 07:36 PM
Bass Traps with style? Boaphile Home Audio Acoustics 48 02-06-07 02:27 PM
Mach 5 Audio
