| REW Forum Can't get past the first stepDiscuss Can't get past the first step in the Subwoofer Equalization | Calibration forum; Can't get past the first step Alright, I'm about to pull my hair out
Trying to get through the first step where you connect the line ... |
| | #1 (Link) | |||
| Can't get past the first step Alright, I'm about to pull my hair out Trying to get through the first step where you connect the line in to the line out on the soundcard. It has a meter on it where you are supposed to adjust the input level so that it matches the output level. I get nothing on the input level no matter what I do. Everything is set up exactly how the directions say to, but I get nothing ![]() Can someone help me out? Nick | |||
| | #5 (Link) | ||||
| Re: Can't get past the first step Quote:
![]() Yeah, show us your REW settings screenshot........ brucek | ||||
| | #7 (Link) | |||
| Re: Can't get past the first step Put the Settings screen up and press Prt Scr key on your keyboard (upper right corner). This copies the screen to the clipboard. Then paste it into Paint or any graphics program and size and crop to 800 wide and SAVE. brucek | |||
| | #8 (Link) | ||||
1. Run the Check Levels routine (in Settings icon) selecting Check/Set Levels with Subwoofer in the Levels pull down box, with the SPL meter at the listening position and the dial of the meter at 80dB position (or whatever scale allows 75dB to be measured). Ensure the REW output VU meter is at -12db and the Sweep Level at -12dB. Set the Wave Volume at 1.000 and the Output Volume about ~0.500. (If those fields are blank, change Input Device and Input and Output Device and Output from Default to USB Audio, or the name of the soundcard, if that options available, and Speaker for output, and Line In for input. Change). Adjust your receivers volume control so the actual standalone Radio Shack SPL meter reads ~75db at the listening position. Then adjust REW Input Volume to end up with -12dB on the REW input VU meter (i.e., matches the Output meter). Regards, Wayne | ||||
| | #10 (Link) | |||
| Re: Can't get past the first step Ok, here's where I'm at. I am trying to calibrate the soundcard. In REW, I am in the soundcard page. Settings are as follows... Output device-SB Live External.....and Speaker Input Device-SB Live External....and Line in/Mic in Wave set to 1.000 Output volume-0.501 Input volume-1.000 Sweep level-12.0 Check/set levels with Subwoofer I have the line out directly conected with the line in, nothing inbetween(is this supposed to go through the preamp?) I click the "measure" button, and follow the directions in the help box on the bottom. In REW's soundcard page, there are 2 level meters, and you are supposed to match the input meter with the output meter. I get -12 on the output meter, and nothing on the input meter. Meaning, nothing is coming back through. This is the point where I am stuck. I am at work, and have my laptop with me here. But, no way to get an internet conection to the laptop, so no screenshots. Nick | |||
| | #11 (Link) | |||
| Re: Can't get past the first step Just an update... In the input device options, if I choose SB Live! External, and "what you hear". I can get the level meter to show the correct position. But the directions specifically state to use "mic in/line in and not "what you hear". I found this persons thread, where he is having the same exact problems. But I don't know where he made his changes. http://www.hometheatershack.com/foru...snt-right.html Help? ![]() | |||
| | #12 (Link) | ||||
| | #13 (Link) | |||
| Re: Can't get past the first step If I use the "headphone" jack on the front of the soundcard, I can also get a good reading. Nothing out of the "front" or "sub" jacks on the back of the soundcard. | |||
| | #14 (Link) | ||||
Following these instructions http://www.hometheatershack.com/room...dcard.html#top It says Connect the soundcard's line output directly to its line input - use the channel that will be used to make system measurements, which should be the same one that has been selected in the Input Channel control. Press the Measure... button on the Soundcard Settings panel and follow the instructions in the help panel This is exactly what I am doing, and I get nothing. It doesn't say to involve the preamp in the loop. Only to connect the line out DIRECTLY to the line in. | ||||
| | #15 (Link) | |||
| Re: Can't get past the first step It is OK to use the headphone output. This is the 2nd time in the last week or so someone has had problems with no output via the "front" jack, must be some setting in Creative's mixer or speaker settings that disables it. | |||
| | #16 (Link) | |||
| Re: Can't get past the first step Ok, thanks John. Things are working well for now. Got the soundcard calibrated. Going to hopfully get everything else set up this afternoon, and get a reading today. Thanks for the help!! Nick | |||
| | #17 (Link) | ||||
| Thread Tools | |
Similar Threads | ||||
| Celebrity Home Theaters past and present | Roger | Home Theater, Audio and Video News | 6 | 08-15-07 07:39 PM |
| How low can the step up be | jgraceoma | Home Theater Design and Construction | 6 | 08-05-07 01:01 AM |
| Baffle step considerations... | aceinc | DIY Speakers | 2 | 05-27-07 02:11 AM |
| Trouble with Baffle Step Compensation Circuits | BoomieMCT | DIY Speakers | 1 | 04-13-07 07:22 PM |
| NHT owners welcome, past and present designs | Exocer | Home Audio Speakers | 17 | 09-22-06 04:02 PM |
