Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
Can't get past the first step
Discuss Can't get past the first step in the Subwoofer Equalization | Calibration forum; Can't get past the first step Alright, I'm about to pull my hair out Trying to get through the first step where you connect the ...
Old 12-28-07, 04:53 PM   #1 (Link)
Alias: Nick
Loc: Dallas, Tx
User: #14623
Since: Dec 2007
n737nc is offline
Trying to get through the first step where you connect the line in to the line out on the soundcard. It has a meter on it where you are supposed to adjust the input level so that it matches the output level.
I get nothing on the input level no matter what I do. Everything is set up exactly how the directions say to, but I get nothing
Can someone help me out?
Nick
Old 12-28-07, 05:29 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: Can't get past the first step
Are you using stereo connectors at the soundcards line-in and line-out?
Old 12-28-07, 05:34 PM   #3 (Link)
Alias: Nick
Loc: Dallas, Tx
User: #14623
Since: Dec 2007
n737nc is offline
brucek wrote: View Post
Yes sir. Just like the ones pictured on the help page. Smaller black ones from Radio Shack.
Old 12-28-07, 05:38 PM   #4 (Link)
Loc: Lower Alabama
Do you have the correct channel selected, input and output devices selected?
Maybe a screen shot of your REW settings page might help.
Old 12-28-07, 05:47 PM   #5 (Link)
Alias: brucek
User: #6
If it's like the one below, how did you identify the right or left channel?
Yeah, show us your REW settings screenshot........
Old 12-28-07, 06:06 PM   #6 (Link)
Alias: Nick
Loc: Dallas, Tx
User: #14623
Since: Dec 2007
n737nc is offline
I've always used red for right. Is that wrong?
How do I do a screen shot on the settings page?
Old 12-28-07, 07:06 PM   #7 (Link)
Alias: brucek
User: #6
Put the Settings screen up and press Prt Scr key on your keyboard (upper right corner). This copies the screen to the clipboard.
Then paste it into Paint or any graphics program and size and crop to 800 wide and SAVE.
Old 12-28-07, 08:29 PM   #8 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Here’s what I have in my REW quickie instructions file:
1. Run the Check Levels routine (in Settings icon) selecting Check/Set Levels with Subwoofer in the Levels pull down box, with the SPL meter at the listening position and the dial of the meter at 80dB position (or whatever scale allows 75dB to be measured).
Ensure the REW output VU meter is at -12db and the Sweep Level at -12dB.
Set the Wave Volume at 1.000 and the Output Volume about ~0.500. (If those fields are blank, change Input Device and Input and Output Device and Output from Default to USB Audio, or the name of the soundcard, if that options available, and Speaker for output, and Line In for input. Change).
Adjust your receivers volume control so the actual standalone Radio Shack SPL meter reads ~75db at the listening position.
Then adjust REW Input Volume to end up with -12dB on the REW input VU meter (i.e., matches the Output meter).
Old 12-29-07, 09:20 AM   #9 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Or use Alt+Print Screen to capture just the currently active window.
Old 12-29-07, 10:29 AM   #10 (Link)
Alias: Nick
Loc: Dallas, Tx
User: #14623
Since: Dec 2007
n737nc is offline
Ok, here's where I'm at.
I am trying to calibrate the soundcard. In REW, I am in the soundcard page. Settings are as follows...
Output device-SB Live External.....and Speaker
Input Device-SB Live External....and Line in/Mic in
Wave set to 1.000
Output volume-0.501
Input volume-1.000
Sweep level-12.0
Check/set levels with Subwoofer
I have the line out directly conected with the line in, nothing inbetween(is this supposed to go through the preamp?)
I click the "measure" button, and follow the directions in the help box on the bottom. In REW's soundcard page, there are 2 level meters, and you are supposed to match the input meter with the output meter.
I get -12 on the output meter, and nothing on the input meter. Meaning, nothing is coming back through.
This is the point where I am stuck.
I am at work, and have my laptop with me here. But, no way to get an internet conection to the laptop, so no screenshots.
Nick
Old 12-29-07, 10:37 AM   #11 (Link)
Alias: Nick
Loc: Dallas, Tx
User: #14623
Since: Dec 2007
n737nc is offline
Just an update...
In the input device options, if I choose SB Live! External, and "what you hear". I can get the level meter to show the correct position. But the directions specifically state to use "mic in/line in and not "what you hear".
I found this persons thread, where he is having the same exact problems. But I don't know where he made his changes. http://www.hometheatershack.com/foru...snt-right.html
Help?
Old 12-29-07, 10:47 AM   #12 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Not sure I get this. The soundcard’s line out should go to the receiver (or pre-amp, as the case may be). The soundcard’s line in should be fed from the SPL meter.
Old 12-29-07, 10:48 AM   #13 (Link)
Alias: Nick
Loc: Dallas, Tx
User: #14623
Since: Dec 2007
n737nc is offline
If I use the "headphone" jack on the front of the soundcard, I can also get a good reading. Nothing out of the "front" or "sub" jacks on the back of the soundcard.
Old 12-29-07, 10:51 AM   #14 (Link)
Alias: Nick
Loc: Dallas, Tx
User: #14623
Since: Dec 2007
n737nc is offline
Following these instructions http://www.hometheatershack.com/room...dcard.html#top
It says
Connect the soundcard's line output directly to its line input - use the channel that will be used to make system measurements, which should be the same one that has been selected in the Input Channel control.
Press the Measure... button on the Soundcard Settings panel and follow the instructions in the help panel
This is exactly what I am doing, and I get nothing. It doesn't say to involve the preamp in the loop. Only to connect the line out DIRECTLY to the line in.
Old 12-29-07, 11:51 AM   #15 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
It is OK to use the headphone output. This is the 2nd time in the last week or so someone has had problems with no output via the "front" jack, must be some setting in Creative's mixer or speaker settings that disables it.
Old 12-29-07, 11:58 AM   #16 (Link)
Alias: Nick
Loc: Dallas, Tx
User: #14623
Since: Dec 2007
n737nc is offline
Ok, thanks John.
Things are working well for now. Got the soundcard calibrated. Going to hopfully get everything else set up this afternoon, and get a reading today.
Thanks for the help!!
Nick
Old 12-29-07, 06:01 PM   #17 (Link)
Alias: Matt
User: #8834
Since: May 2007
Mattlock is offline
n737nc wrote: View Post
It says
Nick...that was my thread that you referenced. When I used "phono" for my line out it worked fine. Later I went back and tried the "Front" connection (next to the line-ine) and that worked fine as well. I struggled for several hours believe it or not and was very frustrated but then someone suggested using phono and it worked. good luck
You may not post new threads, nor post replies, nor post attachments, and you can not edit your posts.
vB code is On, Smilies are On and [IMG] code is On
Similar Threads
Celebrity Home Theaters past and present Roger Home Theater, Audio and Video News 6 08-15-07 07:39 PM
How low can the step up be jgraceoma Home Theater Design and Construction 6 08-05-07 01:01 AM
Baffle step considerations... aceinc DIY Speakers 2 05-27-07 02:11 AM
Trouble with Baffle Step Compensation Circuits BoomieMCT DIY Speakers 1 04-13-07 07:22 PM
NHT owners welcome, past and present designs Exocer Home Audio Speakers 17 09-22-06 04:02 PM
Video Products, Inc. Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct
