Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
calibrating a firewire external sound card?
Discuss calibrating a firewire external sound card? in the Subwoofer Equalization | Calibration forum; calibrating a firewire external sound card? Hi... I have a phonic Helix 24 MKII, 24 channel mixer that is ALSO a firewire 16 simutaneous track recording ...
Old 12-30-07, 04:39 PM   #1 (Link)
Alias: jam
User: #3864
Since: Nov 2006
jamminji is offline
Hi... I have a phonic Helix 24 MKII, 24 channel mixer that is ALSO a firewire 16 simutaneous track recording soundcard. It shows up in REW fine and iIcan do measurements, but I do not understand how to calibrate it since it does not have line in outs that go to the computer, only firewire ins/outs. I have the mic hooked up to ch 15/16. In REW it sees ch15/16 and it sees the correct main L/R out. How would I calibrate this set up?
Also i am using a SONY ECM-ms907 Stereo mic. Is there a cal file for this mic? Or Can I/How can I calibrate the mic also?
thanks... Jam
Old 12-30-07, 05:38 PM   #2 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Re: calibrating a firewire external sound card?
If this is what you have, you calibrate it just as the REW help files say: Feed one of the outputs into one of the inputs. Make sure any the EQ strip is set flat.
Old 12-30-07, 06:28 PM   #3 (Link)
Alias: jam
User: #3864
Since: Nov 2006
jamminji is offline
Yes that is it. But I am confused. This system sends the inputs signals through it's built-in firewire port, and receives signals from the computer via it's built-in firewire port not the 1/4" inputs/outputs. I must be missing something dumb here.
jam
Old 12-30-07, 08:30 PM   #4 (Link)
Alias: jam
User: #3864
Since: Nov 2006
jamminji is offline
This is how I have the system hooked up. Let me know where I go all wrong.
laptop running REW Helix 15/16 input and Helix main L/R output show in REW default input outputs in REW. Firewire cable to the Helix. SONY ECM-907 stereo mic running to helix channel strips 15 and 16. Helix 1/4" main L/R outs running to power amp then to JBL jrx-100 15" and horn PA speakers. I can get the output volume set to 75db using the internal REW generated tones but the only way I can find to adjust input volume is by the pre amp gains on the helix mixer and even with them turned up all the way I am still at about -40db. SO I have to turn up the volume on the amp for the mains and it get WAY to loud. Where am I falling apart?
jam
Old 12-30-07, 09:24 PM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
That’s the correct connection scheme, but for measuring, not for calibrating the soundcard.
If you’re trying to calibrate the soundcard, you’ll need to loop a cable between the main output and the channel strip you intend to use, as indicated in Item #1 in the REW help files for Calibrating the Soundcard.
There should not be a mic connected, or a connection to the sound system, until later when you’re ready to measure.
Old 12-30-07, 09:26 PM   #6 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Also:
You can create your own calibration file, but you’ll need a frequency response graph of the mic in order to do it.
But one thing at a time.
Old 12-30-07, 11:36 PM   #7 (Link)
Alias: jam
User: #3864
Since: Nov 2006
jamminji is offline
Ok got it... I hate plugging directly from ins to outs. But THANKS! ...it worked. Next problem is still the same though. When I do a measurement it tells me that the input is too low so a ctrank up the amp and the sound is piercing but it says too low, reading is about -50 to -40. I still get readings but not sure if they mean anything because of this. I will upload my soundcard graph and new plot. For some reason I get an "error on page" when I try to add an atatchment using this computer. I turned off pop-up blocker, but that did not help. And, Yes after this it is on to the mic!
jam
Old 12-31-07, 10:01 AM   #8 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Why not increase the gain and/or input slider at the channel strip the mic is plugged into?
Old 12-31-07, 03:30 PM   #9 (Link)
Alias: jam
User: #3864
Since: Nov 2006
jamminji is offline
I can do that too. But my question is after i get all the calibration done setting the spl to read what my spl reads (75db) and setting the volumes etc etc. Why do i have to turn up the volume for the measurement to well into the 100db+ range... I am covering my ears even with ear plugs, when the test runs. I think that I still don hae thing set right... agreed?
jim
Old 01-01-08, 08:53 AM   #10 (Link)
Alias: brucek
User: #6
brucek is offline
agreed?
Agreed........
Old 01-01-08, 11:43 AM   #11 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
Can you show us a screen shot of your Settings box, including your input and output levels? That’ll probably provide us with the clues we need.
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
Which external sound card do you recommend? P-P-S-S SPL Meters | Mic's | Calibration 9 02-23-08 08:48 PM
External sound card question canaris REW Forum 5 04-17-07 07:26 AM
Looking for a hi-fi sound card Wayne A. Pflughaupt Computers | Games | HTPC | Digital Devices 26 04-15-07 07:04 AM
Compile lists of compatible external sound card? MichaelSim REW Forum 10 02-07-07 03:49 PM
External sound card The G REW Forum 2 12-28-06 08:52 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85
