| REW Forum calibrating a firewire external sound card?Discuss calibrating a firewire external sound card? in the Equalization | Calibration forum; calibrating a firewire external sound card? Hi... I have a phonic Helix 24 MKII, 24 channel mixer that is ALSO a firewire 16 simutaneous track recording ... |
Views: 502 - Replies: 10
| calibrating a firewire external sound card? Hi... I have a phonic Helix 24 MKII, 24 channel mixer that is ALSO a firewire 16 simutaneous track recording soundcard. It shows up in REW fine and iIcan do measurements, but I do not understand how to calibrate it since it does not have line in outs that go to the computer, only firewire ins/outs. I have the mic hooked up to ch 15/16. In REW it sees ch15/16 and it sees the correct main L/R out. How would I calibrate this set up? Also i am using a SONY ECM-ms907 Stereo mic. Is there a cal file for this mic? Or Can I/How can I calibrate the mic also? thanks... Jam | ||||
| | #3 | |||||
| Re: calibrating a firewire external sound card? Quote:
jam | |||||
| | #4 | ||||
| Re: calibrating a firewire external sound card? This is how I have the system hooked up. Let me know where I go all wrong. laptop running REW Helix 15/16 input and Helix main L/R output show in REW default input outputs in REW. Firewire cable to the Helix. SONY ECM-907 stereo mic running to helix channel strips 15 and 16. Helix 1/4" main L/R outs running to power amp then to JBL jrx-100 15" and horn PA speakers. I can get the output volume set to 75db using the internal REW generated tones but the only way I can find to adjust input volume is by the pre amp gains on the helix mixer and even with them turned up all the way I am still at about -40db. SO I have to turn up the volume on the amp for the mains and it get WAY to loud. Where am I falling apart? jam | ||||
| | #5 | ||||
| Re: calibrating a firewire external sound card? That’s the correct connection scheme, but for measuring, not for calibrating the soundcard. If you’re trying to calibrate the soundcard, you’ll need to loop a cable between the main output and the channel strip you intend to use, as indicated in Item #1 in the REW help files for Calibrating the Soundcard. There should not be a mic connected, or a connection to the sound system, until later when you’re ready to measure. Regards, Wayne | ||||
| | #6 | |||||
| Re: calibrating a firewire external sound card? Also: Quote:
But one thing at a time. ![]() Regards, Wayne | |||||
| | #7 | |||||
| Re: calibrating a firewire external sound card? Ok got it... I hate plugging directly from ins to outs. But THANKS! ...it worked. Next problem is still the same though. When I do a measurement it tells me that the input is too low so a ctrank up the amp and the sound is piercing but it says too low, reading is about -50 to -40. I still get readings but not sure if they mean anything because of this. I will upload my soundcard graph and new plot. For some reason I get an "error on page" when I try to add an atatchment using this computer. I turned off pop-up blocker, but that did not help. And, Yes after this it is on to the mic! jam Quote:
| | #8 | |||||
| | #9 | ||||
| Re: calibrating a firewire external sound card? I can do that too. But my question is after i get all the calibration done setting the spl to read what my spl reads (75db) and setting the volumes etc etc. Why do i have to turn up the volume for the measurement to well into the 100db+ range... I am covering my ears even with ear plugs, when the test runs. I think that I still don hae thing set right... agreed? jim | ||||
| | #11 | ||||
| Re: calibrating a firewire external sound card? Can you show us a screen shot of your Settings box, including your input and output levels? That’ll probably provide us with the clues we need. ![]() Regards, Wayne | ||||
