No input - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
No input
Discuss No input in the Subwoofer Equalization | Calibration forum; No input From the scope plot there's still some kind of EQ curve being applied, i.e. the kind of effect that gets ...
Old 01-10-08, 04:23 AM   #26 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: No input
From the scope plot there's still some kind of EQ curve being applied, i.e. the kind of effect that gets labelled "rock" or "jazz" or some such.
Old 01-11-08, 05:40 PM   #27 (Link)
Alias: Tom Edward
Loc: Southern Califoria
User: #14370
Since: Dec 2007
Tom Edward is offline
Re: No input
How does this look for a sound card calibration? Tom
Old 01-11-08, 06:19 PM   #28 (Link)
Alias: brucek
User: #6
brucek is offline
Re: No input
What are the two lines?
Would rather see the graph from 0Hz-20000Hz after you do the calibration with the small axis...
Old 01-12-08, 04:17 PM   #29 (Link)
Alias: Tom Edward
User: #14370
Since: Dec 2007
Re: No input
I think I've got it. I was about to call it quits last night so I waited till this morning to try it again. I got a flat line for my sound card calibration and did a measurement of the sub under the desk for the computer. I hope this is what it is supposed to look like. Tom
Old 01-12-08, 10:08 PM   #30 (Link)
Alias: brucek
User: #6
brucek is offline
Re: No input
Good.....
Yep, except for a couple of suggestions.
Use the standard graph axis we all use here of vertical=45dB-105dB and horizontal=15Hz-200Hz. These values are entered into the Graph Axis button popup and recalled at any time to return the graph to these standard value.
When you measure a sub, you do it with the mains turned off and the crossover turned on so it will match that target line on the graph (hopefully).
Calibrate the REW target to 75dB when you measure.
Similar Threads
No input mixers available bennychico11 REW Forum 9 05-02-08 01:24 AM
low input bobmills REW Forum 41 07-07-07 04:36 PM
What to use for input Mopar_Mudder REW Forum 4 02-07-07 03:19 PM
Input Level -4/-5, ok? daxie BFD Forum 4 01-22-07 11:49 AM
Max Sub Input Gizmo BFD Forum 2 12-29-06 03:01 PM
Mach 5 Audio
