REW Forum
No input
Discuss No input in the Equalization | Calibration forum; No input I have racked my brain and tried everything I can think of and read the posts and help files. I ...
Views: 779 - Replies: 29
Old 01-04-08, 03:48 PM   #1
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
No input
I have racked my brain and tried everything I can think of and read the posts and help files. I can't get any input. I can get the generator to work. I tried the spl meter (Radio Shack 33-2055 digital) and The EMC 8K and UB802 and no sound at all. Tom
Old 01-04-08, 04:30 PM   #2
Alias: brucek
User: #6
  brucek is offline
Re: No input
OK Tom, let's see if we can solve your problem.
You have a few other posts going that I re-read through, so we'll stick to this thread.
You have the Creative Sound Blaster X-Fi Extreme Audio card. No problem there.
The first thing you want to do is the Soundcard calibration.
Have you connected a stereo cable from line-out to line-in and run the soundcard calibration routine?
Old 01-04-08, 05:43 PM   #3
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
Re: No input
OK, I got the sound card calibrated but I had to use "what you hear" for the input. Tom
Old 01-04-08, 06:35 PM   #4
Alias: brucek
User: #6
  brucek is offline
Re: No input
No, the 'what you hear' option is a monitor mode that internally loops the output back to the input. This must be shut off before you are actually looking at the line-in port and not simply looping your output back to itself.
Are you using a cable that uses stereo connectors connected from line-out to line-in?
Old 01-04-08, 09:42 PM   #5
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
Re: No input
The cables I'm using have a mini stereo at one end and two RCA's coming out of it. One red and one white. The cables are connected together with RCA couplers. Will these work? Tom
Old 01-04-08, 09:51 PM   #6
Alias: brucek
User: #6
  brucek is offline
Re: No input
Yep, that sounds good.
You need to be sure the card is in stereo mode with all effects and monitoring mode off before doing the soundcard cal routine.
Old 01-04-08, 10:07 PM   #7
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
Re: No input
It's in stereo mode with all effects off. Tom
Old 01-04-08, 10:51 PM   #8
Alias: brucek
User: #6
  brucek is offline
Re: No input
Did you get a proper level setting and graph produced when you did the soundcard routine?
Old 01-04-08, 11:15 PM   #9
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
Re: No input
No. Tom
Old 01-05-08, 07:53 AM   #10
Alias: brucek
User: #6
  brucek is offline
Re: No input
Can you post a picture of your REW settings page and also one of your Windows record and playback mixer screen.
Old 01-06-08, 12:57 PM   #11
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
Re: No input
Here's the graph with the mixer included.
I'm still tryimg to figure out how to post a pic of the windows control.
Old 01-06-08, 01:31 PM   #12
Alias: brucek
User: #6
  brucek is offline
Re: No input
You have the C-Weight box checked in REW. It needs to be Un-checked.
What is the graph of? Is this the result of a measurement of the direct loopback of the line-out to line-in plugs on the soundcard after you successfully did a soundcard calibration?
Any active screen on the Windows desktop may be captured by pressing ALT and PrtScr keys. Then that can be pasted into Paint or any other graphics program and sized to 800 wide and posted as a jpeg.
Old 01-06-08, 09:19 PM   #13
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
Re: No input
It was supposed to be a measurement of the direct loopback of the line-out to line-in plugs of the sound card but since I have no input it's not right. I did confirm the the spl meter is working. I'm still working on posting the windows record/playback. Tom
Old 01-06-08, 10:07 PM   #14
Alias: brucek
User: #6
  brucek is offline
Re: No input
Here's what I'd like to see if possible.
1. REW setup page
2. Windows playback mixer
Name:  Mixer Playback.jpg
3. Windows record mixer
Name:  Mixer record.jpg
Old 01-07-08, 10:40 AM   #15
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
Re: No input
If the pics of the Windows control and the set up page show the settings the way they should be , then I have everything set up like the pics. Is that right? Tom
Old 01-07-08, 11:10 AM   #16
Alias: brucek
User: #6
  brucek is offline
Re: No input
Yeah, you want to be sure your card is recognized in REW and that you select line/speaker out and line-in as shown in my pic.
Then in Windows, you want to be sure that Master Volume and Wave are enabled and that line-in is muted in Playback and that line-in is enabled in Record.
Then if you have a proper stereo cable from line-out to line in, it should simply work....... if not, you've got likely got a fault.
Old 01-09-08, 01:31 PM   #17
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
Re: No input
Ok, I have set everything according to your pics and suggestions, I even uninstalled REW and re installed it and still no input. I noticed that in your pics of the control panel they are with Realtek AC97. I still have this in my computer but Creative is over riding it. Will Realtek work with REW? Tom
Old 01-09-08, 01:58 PM   #18
Alias: brucek
User: #6
  brucek is offline
Re: No input
Yep....... works fine. You'd have to enable it in bios and ensure it's the default card.
Old 01-09-08, 02:32 PM   #19
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
Re: No input
I enabled Realtek and I have input now. Thanks. Tom
Old 01-09-08, 02:38 PM   #20
Alias: brucek
User: #6
  brucek is offline
Re: No input
I'm beginning to lose faith in these Creative soundcards, because you aren't the first one to complain for sure. All sorts of strange problems.....
I hope the RealTek gets you going.
Old 01-09-08, 03:27 PM   #21
Alias: Mike Bentz
DrWho's Avatar
Loc: Chicago
User: #2782
Since: Sep 2006
  DrWho is offline
Re: No input
There is nothing wrong with the Creative cards - you just need to configure them using their actual setup software instead of windows...there is a way to make the Creative software do what you tell Windows to do, but that is a setting inside their configuration utility. (assuming you're not using vista)
-Mike Bentz
~It's all about compromise~
"It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!"
Old 01-09-08, 05:58 PM   #22
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
Re: No input
Sound card calibration. What went wrong? Tom
Old 01-09-08, 06:41 PM   #23
Alias: brucek
User: #6
  brucek is offline
Re: No input
Usually cause by a soundfield or effects turned on in the soundcard. Set it to simple stereo with no equalizer.
Also can be caused by an incorrect level setup in the soundcard routine.
Old 01-09-08, 08:17 PM   #24
Tom Edward
Inactive
Alias:
User: #
Posts: n/a
Re: No input
Does this look better? Tom
Old 01-09-08, 08:57 PM   #25
Alias: brucek
User: #6
  brucek is offline
Re: No input
You have the C-Weight box checked in REW Settings. Uncheck it.
After unchecking it, do the soundcard cal file routine and lets see the full graph....
Save the file and do a test measure and the response should be a perfect flat line....
