Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
Equalizing for a large listening area (9 chairs)
Discuss Equalizing for a large listening area (9 chairs) in the Subwoofer Equalization | Calibration forum; Equalizing for a large listening area (9 chairs) Hello calling all REW experts :-) My first attempt with the REW program a wonderful tool thanks for making it. The ...
Old 01-07-08, 05:03 AM   #1 (Link)
New Member
Alias: Kallagtunet
User: #6335
kallagtunet is online now
My first attempt with the REW program a wonderful tool thanks for making it. The other equipment i use is the Berhinger 8000 mic and a M-audio Solo firewire soundcard
I have a home cinema with 9 seats divided in 3 rows. The back row is up against the back wall and im not trying to do anything to equalize that challenge. The sub i have is for the time being SVS BP pluss/2 (not the sub with the flattest response from 45hz and up I understand). A pair of new subs is incoming (JL A F113). The SVS is located in front between right speaker and center. There are no other places in the room to have subs than between the front speakers and the center channel.
The first row the response look quite flat in the low end, on the second row I have a rather large top at 25hz. But in both locations I have a rather large recessed area between the 50 and 150 hz with both sub and main speakers running. I have tried to adjust phase and that seems to tame a narrow dip around 80 hz. And it seems to be a tradeoff between having a deep narrow dip and a wide and deeply recessed area or a sharp dip at 80 hz and a not so deep recessed area. See the two first row graphs.
Any hints of how to make the rater wide recessed area to best be chandelled?
The second row has a high top at 25 hz (se second row graph), I see that that can be tamed with the PEQ, but then probably I will get a similar dip at the front row. Any hints on best handling this?
I have not tried to apply any PEQ just yet hopefully some of you expert can lead me in the right direction before I start the Berhinger up :-)
Yes, I have just started this journey as you probably understand....
File Type: jpg response front row with different phase adjustments.jpg (187.6 KB, 51 views)
Old 01-07-08, 07:36 AM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: Equalizing for a large listening area (9 chairs)
For sub measurements the standard REW graph axis to use is vertical 45-105dB and horizontal 15-200Hz. These can be entered and recalled any time into the Graph Limits Icon. Also make them 800 wide so as to fit the screen.
Your best bet when you're attempting to get a decent response across a large area is to take a number of readings (up to 8) and then Average them all using the average feature on the Averaging Tab. This will produce a new average response that you can then equalize. It's a compromise, but other than moving the listening position or sub positions, it's the best you can do.
Old 01-07-08, 08:09 AM   #3 (Link)
New Member
Alias: Kallagtunet
User: #6335
I try again, the curves in one chart this time. Both sub an mains playing.
Old 01-07-08, 08:22 AM   #4 (Link)
Alias: brucek
User: #6
Yeah, doesn't look too bad other than a consistent dropping around 80Hz. Perhaps playing with the phase could help there. Try some different settings that result in the best average response.
You may not post new threads, nor post replies, nor post attachments, and you can not edit your posts.
vB code is On, Smilies are On and [IMG] code is On
Similar Threads
How do Berkline HT chairs compare to Palliser? technimac Home Theater Seating and Accessories 10 11-02-07 12:24 PM
Large H/T Subwoofer system 95Honda DIY Subwoofers - Sealed and Ported 18 10-27-07 09:31 AM
Large or Small ? sonata31 Home Audio Speakers 18 02-15-07 09:58 PM
Large vs. Small nova General Discussion 17 01-30-07 10:52 PM
Working at equalizing SVS pcultra with HK. wmilas REW Forum 5 09-03-06 09:29 PM
Video Products, Inc. Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
Search Engine Friendly URLs by vBSEO 3.1.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173
