1st Runs on my HT System - Page 2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss 1st Runs on my HT System in the Subwoofer Equalization | Calibration forum; 1st Runs on my HT System Looks good. Can REW be used to calibrate the centre channel's freq response? If so, which input on the receiver ...
Old 01-09-08, 01:46 PM   #26 (Link)
Alias: brucek
User: #6
brucek is offline
Re: 1st Runs on my HT System
Looks good.
Can REW be used to calibrate the centre channel's freq response? If so, which input on the receiver would be used, as obviously the L or R inputs can't be. Would you use the Multichannel's centre input?
You could use the multichannel input, but would your eq system in the receiver be engaged on multichannel? I thought the multichannel inputs were fairly direct? Either way, the multi would give you a look at the response anyway.
Old 01-09-08, 01:57 PM   #27 (Link)
Alias: Joe
Loc: Canada
User: #14736
Since: Dec 2007
Sittler27 is offline
brucek wrote: View Post
Looks good.
You are right.
Is there any other common way to do it?
Old 01-09-08, 05:44 PM   #28 (Link)
Alias: brucek
User: #6
brucek is offline
Not that I know of. We don't usually concern ourselves with the center and surrounds with respect to REW. It is more for a sub and mains at the crossover.
Old 01-09-08, 06:13 PM   #29 (Link)
Alias: Joe
Loc: Canada
User: #14736
Since: Dec 2007
Another question:
After I take a measurement of the mains+sub, and am ready to Set Target, do I use the Subwoofer setting while Setting Target (which generates the Subwoofer signal) or the Full Band while Setting Target (which generates the Speaker Cal signal). Reason I ask is because the Subwoofer setting and signal generates a louder Target level than the other.
Old 01-09-08, 07:03 PM   #30 (Link)
Alias: brucek
User: #6
brucek is offline
You use the subwoofer signal since you're really testing band limited to 200Hz even though the mains are on..............
Old 01-09-08, 08:03 PM   #31 (Link)
Alias: Joe
Loc: Canada
User: #14736
Since: Dec 2007
Ok, here are my mains+sub final settings for each seat in the room.
Top to bottom:
Seat 1 (primary seating position i.e. my favourite seat because it reclines )
Seat 2 (best listening position between both mains)
Seat 3
Seat 4 (wife's favourite seat because she can lay on the couch)
Seat 5
Seat 6
Any more advice for the HT room before I pack it in and call it the best I can do? Should I pump up the sub a bit more? It seems low for Seat 1.
Old 01-09-08, 09:07 PM   #32 (Link)
Alias: brucek
User: #6
brucek is offline
It is tough to get a great response over a large listening area, but I think your response is pretty good. #2, 3, 4 are the best, but overall they're pretty good. I think the sub level with respect to the mains looks perfect now...
Similar Threads
1st attempt at REW cburbs REW Forum 40 02-06-08 05:22 PM
1st day using REW muzz REW Forum 19 08-03-07 06:11 PM
1st Graph--how's it look? allredp REW Forum 17 04-06-07 04:03 PM
1st post. newbie ? pwest Home Audio Subwoofers 7 11-11-06 10:05 PM
1st graph (before) union1411 REW Forum 6 05-14-06 05:40 PM
Mach 5 Audio
