Problems calibrating soundcard Edirol in Macos - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
REW Forum
Discuss Problems calibrating soundcard Edirol in Macos in the Subwoofer Equalization | Calibration forum; Problems calibrating soundcard Edirol in Macos Here's another Mac Newb from The Netherlands. Just started, in REW and in this forum, both of which are great, ...
Old 01-11-08, 08:59 AM   #1 (Link)
New Member
Alias: jean c
Loc: Oisterwijk, Netherlands
User: #15371
Since: Jan 2008
jeancoum is offline
Here's another Mac Newb from The Netherlands. Just started, in REW and in this forum, both of which are great, I think. I want my room optimized (hard surfaces, loads of echoes etc) with sound absorbers and diffusers. This app should be the killer for me!!
The app appears to run fine, but I can't get past the first hurdle: calibrating my soundcard Edirol UA-3d (which normally works fine in both playback I-Tunes and in recording albums). When I open the Settings-window to calibrate the soundcard, and click the Measure-button, I get a pop-up, that titles 'Unable to take SPL reading' with the following message: 'SPL meter audio input not available. This has probably to do with the strange message at start-up: 'No input mixers available supporting PCM-SIGNED 48000.0Hz, 16 bit, stereo, 4bytes/frame, little endian'. I can bypass this message and REW starts fine.
Sample rate is at 48, and not at the advised 44,1, because the app crashes if I try to change it. Input channel is Right, so my loop goes from line-out right to line-in right. Output device is Default device, and it is properly selected (from what I can tell) in my system preferences. Java 5, Macos 10.4.8
Please help.
Old 01-11-08, 11:04 AM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: Problems calibrating soundcard Edirol in Macos
You are a bit scuppered, unfortunately, unless you can use the on-board audio. Apple's Java virtual machine doesn't provide any access to audio inputs other than the on-board input and gets very upset if you try 48k instead of 44.1k. Leopard has, i'm told, sorted out at least the inability to access other audio input devices but I don't know whether it solves the 48k problem. There are also a range of rendering and component size problems under OS X with the current build of REW, but I have sorted those out in the next build which is being beta tested at the moment.
Old 01-11-08, 03:55 PM   #3 (Link)
New Member
Alias: jean c
User: #15371
Since: Jan 2008
jeancoum is offline
Thx John,
Glad it's not me wasting anyones (your) time because I'm a cluts, didn't read the manual properly or made some stupid mistakes.
I'll just wait for my Macbook with Leopard to return after a minor repair (expected on monday) and try again. Hopefully I'll be succesfull, otherwise I'll try the onboard sound. In both cases, I'll report back (also for future references).
Otherwise, you've done a great job sofar. Good luck on the development.
Grz, Jean
Similar Threads
Calibrating Soundcard- Something isnt right Mattlock REW Forum 8 12-30-07 05:00 PM
Problem calibrating soundcard 24bit Live yswong REW Forum 5 10-18-07 07:25 AM
Soundcard problems: Native Instruments Audio Kontrol 1 warrensomebody REW Forum 2 09-15-07 06:10 PM
REW Issue #1: Calibrating SoundCard JCD REW Forum 7 05-01-07 05:08 PM
Edirol UM 1s Hakka REW Forum 2 09-20-06 12:35 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
