Problems with Input and Ouput SB Live - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Problems with Input and Ouput SB Live in the Subwoofer Equalization | Calibration forum; Problems with Input and Ouput SB Live I have an internal SBLive card. It's the only sound card in the computer. When I try to calibrate my ...
Old 01-12-08, 06:50 PM   #1 (Link)
Alias: treeman
Loc: Cary, N.C.
User: #12738
Since: Oct 2007
kbgl is offline
When I try to calibrate my card, I get a message " SPL Meter Audio Input Not Available".
On the REW setting page, I set the input and output as default, and I also tried other settings, but nothing seems to work. All I can seem to get is error messages.
Old 01-12-08, 10:02 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: Problems with Input and Ouput SB Live
Did you look through this thread ? I know it's for the external card, but the application data is the same......
Does REW recognize the card in the Settings page for selection as Input and Output?
Tell me about the loopback cable you're using for the soundcard calibration?
Can you post a picture of your Windows Playback and Record mixers?
Old 01-12-08, 10:54 PM   #3 (Link)
Alias: treeman
Loc: Cary, N.C.
User: #12738
Since: Oct 2007
kbgl is offline
I looked through that thread and a few others briefly, but the problem is different I think.
The setting page shows the card in the drop down boxes along with Default and java. If I select the SB card for the output, it gives me an "output device error". If I select the SB card for the input, it gives me an "input device error". The drop down boxes under both are grayed out.
I don't think the loop back cable is the problem. I get the same messages without the cables,
How do I copy the screen?
Old 01-13-08, 06:24 AM   #4 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Hit “Control” and “Print Screen” simultaneously, then paste into Paint. Save to a file, then edit as needed in whatever picture editing program you have. Typically the picture has to be shrunk down to 800 x 800 or less in order to upload here (see here for details on that). Or, you can upload it to your own server and post the link, or put the link in image tags to show it on your post.
Old 01-13-08, 08:37 AM   #5 (Link)
Alias: treeman
Loc: Cary, N.C.
User: #12738
Since: Oct 2007
kbgl is offline
Here's one.
Old 01-13-08, 08:52 AM   #6 (Link)
Alias: treeman
Loc: Cary, N.C.
User: #12738
Since: Oct 2007
kbgl is offline
This is what I get when I start REW. After I click OK, I get the same message for input.
Old 01-13-08, 09:22 AM   #7 (Link)
Alias: brucek
User: #6
Your card isn't being recognized by REW for some reason.
You should be able to control the card with Windows though.
Select DEFAULT for both Input and Output and use the Windows mixers to control the setup levels and see how that goes.
Below are the Windows Playback and Record settings from my system.
It shows the two mixers and their interaction with REW. See how that goes...
PLAYBACK MIXER
RECORD MIXER
REW MIXER
Old 01-13-08, 09:52 AM   #8 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
Try selecting 48kHz and check that the SB Live is configured to use 48kHz and 16 bits in the Creative Device Control panel. Which version of Windows are you running?
Old 01-13-08, 12:09 PM   #9 (Link)
Alias: treeman
Loc: Cary, N.C.
User: #12738
Since: Oct 2007
kbgl is offline
From the control panel.
Old 01-13-08, 12:29 PM   #10 (Link)
Alias: treeman
Loc: Cary, N.C.
User: #12738
Since: Oct 2007
kbgl is offline
I'm using w98 with an upgrade to milenium. Is this the right java version?
Old 01-13-08, 12:41 PM   #11 (Link)
Alias: treeman
Loc: Cary, N.C.
User: #12738
Since: Oct 2007
kbgl is offline
Here's my control panel. I can't find a mixer like yours Bruce.
Old 01-13-08, 01:13 PM   #12 (Link)
Alias: brucek
User: #6
Double click the little speaker in your system tray to reveal the Playback Mixer.
Select options / properties to switch between Playback and Record Mixer......
Latest JAVA
Old 01-13-08, 01:45 PM   #13 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is online now
Sounds like a driver issue. JavaSound requires DirectSound drivers, which are part of DirectX. You could try updating DirectX on the PC (see http://support.microsoft.com/default...d=fh;DE;drxint) but there may be problems with the driver models used on Windows 98 & ME, which differ from Windows 2000/XP etc.
Old 01-13-08, 06:31 PM   #14 (Link)
Alias: treeman
Loc: Cary, N.C.
User: #12738
Since: Oct 2007
kbgl is offline
I tried a second sound card, but had no luck with it either. I have another computer with XP on it. I think I'll start over with it.
Thanks for the help!
Old 01-13-08, 06:34 PM   #15 (Link)
Alias: Brent
Loc: Wilmington, NC
brent_s's Avatar
User: #7037
brent_s is offline
kbgl wrote: View Post
What other values are in the drop downs? I would think you would want your default playback device to be 'speakers" and your recording device to be "line in/mic in"...not Wave Out/In for both. At least that's how it works with the Live! External.
-Brent
Old 01-13-08, 10:10 PM   #16 (Link)
Alias: treeman
Loc: Cary, N.C.
User: #12738
Since: Oct 2007
kbgl is offline
That's the only option in the drop downs.
Similar Threads
No input Tom Edward REW Forum 29 01-12-08 10:08 PM
No Input Levels AT ALL! gbondioli BFD Forum 16 01-06-08 07:47 AM
Z3 problems... Rodny Alvarez Home Theater Projectors 2 10-15-07 08:07 AM
Input on new setup Fezzy Home Audio Speakers 8 04-16-07 11:08 AM
What to use for input Mopar_Mudder REW Forum 4 02-07-07 03:19 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96
