Trouble using under OS 10.3 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Trouble using under OS 10.3 in the Subwoofer Equalization | Calibration forum; Trouble using under OS 10.3 I want to use REW under OS 10.3. I read the following in the readme file, but I do not ...
Old 01-16-08, 10:23 AM   #1 (Link)
New Member
Alias: John
Loc: New York, NY
User: #15588
Since: Jan 2008
johnlink is offline
I want to use REW under OS 10.3. I read the following in the readme file, but I do not see J2SE 5.0 in /Applications/Utilities/Java:
N.B. On Mac platforms ensure the V5.0 JRE is selected to run applications:
- Open the Java Preferences application in /Applications/Utilities/Java/J2SE 5.0/
- In the "Java Application Runtime Settings" panel, drag J2SE 5.0 to the top of the list (above J2SE 1.4.2).
- Click Save.
Can anyone offer any assistance?
Thanks,
John Link
Old 01-16-08, 10:44 AM   #2 (Link)
New Member
Alias: John
Loc: New York, NY
User: #15588
Since: Jan 2008
johnlink is offline
Re: Trouble using under OS 10.3
It seems that I have to be running OS 10.4 in order to use J2SE 5.0. Is that right?
John Link
Old 01-16-08, 11:46 AM   #3 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
John, I believe you do need 10.4 for JRE 5. Even with 10.4 there are problems getting REW to run, the latest version (currently undergoing beta tests) is better but it seems that REW runs with least hassle under Leopard.
Similar Threads
Anyone else having trouble using the Search? E-A-G-L-E-S Forum Help | Suggestions 4 11-17-07 01:26 AM
Someone having trouble registering Deane Johnson Forum Help | Suggestions 4 01-01-07 02:31 PM
trouble setting up input Tonio REW Forum 6 06-20-06 05:22 PM
Help please - Calibration Trouble zorax2 REW Forum 9 04-28-06 11:10 AM
Mach 5 Audio
