| REW Forum Soundblaster Live! 24-bit USB External SetupDiscuss Soundblaster Live! 24-bit USB External Setup in the Subwoofer Equalization | Calibration forum; Soundblaster Live! 24-bit USB External Setup I believe with the new creative drivers and the new software, as of March 11 2008. the software works under ... |
| | #52 (Link) | |||
| Re: Soundblaster Live! 24-bit USB External Setup You're right. I got things to work today just fine - had one of those "DUH!" moments regarding my SPL meter I was using as a microphone. Everything works fine on my Vista PC. | |||
| | #53 (Link) | ||||
| Re: Soundblaster Live! 24-bit USB External Setup Quote:
So, in the Settings page, do you see the SoundBlaster card in the Output Device and Input Device selection pulldowns? Previously, REW had no access to the card and Default had to be chosen. If you are indeed able to select the SoundBlaster card now, then is the Wave Volume and Output Volume and Input Volume not grayed out anymore? Do you have control of these parameters in VISTA? brucek | ||||
| | #54 (Link) | ||||
Thanks, Doug | ||||
| | #55 (Link) | ||||
Here's my current issue. When calibrating my sound card, I cant get the output and input any closer together than about 8dB. That's way too far off to be making accurate measurements. I've maxed the input for the SoundBlaster, and maxed the output as well, as REW suggests when you can't adjust with REW itself, but I'm seeing about 8dB of separation. Any suggestions? Edit: the input volume is too low and can't get high enough in relation to the output volume. Last edited by lalakersfan34; 04-12-08 at 07:46 PM. | ||||
| | #56 (Link) | ||||
Connect a cable on both left and right channels with the left channel calibrate checkbox ticked and take a measure and see if you get a nice flat line... brucek | ||||
| | #58 (Link) | |||
| Re: Soundblaster Live! 24-bit USB External Setup Ok, I just calibrated it and it seemed to work fine. Here's a link to a picture of the calibration. Please tell me if it looks ok. Thanks .http://s245.photobucket.com/albums/g...alibration.jpg | |||
| | #60 (Link) | |||
| Re: Soundblaster Live! 24-bit USB External Setup . Thanks for your help, Bruce. Looks like the SB Live! 24 USB works with Vista. Incidentally, I installed the drivers on the CD that came with the card and updated the drivers, but ended up deleting them all from my PC. Creative's "Vista" drivers might actually cause problems. I don't know that for a fact, but just thought I'd let everyone know that this is without Creative's drivers. | |||
| | #61 (Link) | ||||
Jeff | ||||
| | #62 (Link) | ||||
It's very easy once you think about it. Doug | ||||
| | #63 (Link) | |||||
brucek | |||||
| | #64 (Link) | |||
| Re: Soundblaster Live! 24-bit USB External Setup Well, I've yet to see any other recommendations on USB soundcards that sounded too great. I also saw some more recent posts (March 08) that indicated the newer version of the SB software is working well with Vista. It also sounds like I can use the card just fine without the SB software. Am I losing out on anything in terms of REW functionality without having the Soundblaster software installed? Thanks, Jeff | |||
| | #65 (Link) | |||||
brucek | |||||
| | #66 (Link) | |||
| Re: Soundblaster Live! 24-bit USB External Setup Well, I was hoping to use the SB for a few reasons. Mostly, it seems to be the most widely used external card for REW users. Another reason is that it was cheaper than the turtle beach card, and I'm not going to be using this for much beyond my initial setup and tweaking of my speaker placement. The last thing is that I wanted to get started this weekend and I was able to pick up the SB. However, I agree with your point that tricking out the monitor is not an idea solution. If that's really the only option, I'll return it and order the turtle beach. Better yet - maybe I'll install XP on this laptop instead of this piece of crap OS. Jeff | |||
| | #67 (Link) | ||||||
brucek | ||||||
| | #68 (Link) | |||
| Re: Soundblaster Live! 24-bit USB External Setup OK...can someone just explain to me simply why I don't want to use this card with REW and Vista? I'm fairly new to REW so that may be why I don't understand the issues mentioned above. I did see lakersfan mention that it is working, so I must be missing some shortcoming. Is this related to the fact that REW isn't able to control the volume on this device due to issues with the driver? How exactly does this impact me? Thanks for the help. Just getting a bit confused. I am probably going to return this thing (not yet opened) but was really hoping I could make it work. Thanks | |||
| | #69 (Link) | |||
| Re: Soundblaster Live! 24-bit USB External Setup There have been problems with this card not working with Vista, until recently lalakersfan34 reporrted that now it does work. I've never personally tried the card. I only know what has been reported from threads like this. It may be just fine now. It would be interesting to know if the card now works with VISTA combined with the SoundBlaster supplied drivers, along with no jiggery pokey required to make it work...... brucek | |||
| | #70 (Link) | |||
| Re: Soundblaster Live! 24-bit USB External Setup OK...I started setting my SB up with Vista and am running into some slightly different issues. Unlike lakersfan, I was able to get the input and output DB within the 3DB threshold. To do this, I had to turn the input AND output volume up all the way. The problem came when I built the calibration file, and went to run a test measurement with the loopback still in place. When doing the 'test volume' it tells me that the volume is too high. The issue here is that, when I turn it down, I end up outside of the 3DB threshhold between the Input and Output. The question is - is that volume high warning an issue or not? I still seemed to get what I believe is a good graph when I ran it. I'll try to post one later if that's helpful. Thanks, Jeff | |||
