| REW Forum Suggestion: Temp graphsDiscuss Suggestion: Temp graphs in the Subwoofer Equalization | Calibration forum; Suggestion: Temp graphs Hi!
I'm in the process of placing room treatments, and I'm doing alot of sweeps in alot of different positions. ... |
| | #1 (Link) | |||
| Suggestion: Temp graphs Hi! I'm in the process of placing room treatments, and I'm doing alot of sweeps in alot of different positions. Most of these sweeps are discarded after looking at them briefly. It would be awesome to make one curve 'master' or reference, and do temporary sweeps overlaid. Then the next sweep would overwrite the previous, but the master sweep stays. Is something like this possible? | |||
| | #2 (Link) | |||
| Re: Suggestion: Temp graphs Yep, just use the All Measured tab to overlay any measures you take......... Turn them on or off with the checkboxes. Or you can wait for the next version of REW and use the RTA feature to do it in real time and watch the effect live.. brucek | |||
| | #3 (Link) | |||
| Re: Suggestion: Temp graphs That's the way I have been doing it, but with so many sweeps, deleting them becomes tedious... Yeah, I'm lazy... ![]() The new RTA, how accurate will it be, ie how many bands? TrueRTA is not really accurate enough for low frequency work. | |||
| | #4 (Link) | ||||
| Re: Suggestion: Temp graphs Quote:
Here's a quick sweep measure of my office sub, and then with the mic in the same position I turned on the RTA. You can see they're fairly close. It's handy to have the measure on the screen and then the RTA overlayed and then move the mic around to see the real time change.... SUB-office-with-RTA.jpg brucek | ||||
| | #5 (Link) | |||
| Re: Suggestion: Temp graphs That looks like it would do the job! Got an approximate date for this update? 1/24 octave for trueRTA is a little coarse, but I guess I can use it to narrow down problemlocations and then measure accurately with REW. | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Suggestion: Turn off the Search limit of 1 in 30 seconds - Very annoying | tradewinds | Forum Help | Suggestions | 1 | 11-27-07 11:01 PM |
| Suggestion | Fincave | Forum Help | Suggestions | 23 | 01-08-07 11:10 PM |
| New Logo Suggestion | Sonnie | Forum Announcements | News | 11 | 09-29-06 12:46 PM |
