Noob question on RS SPL - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Noob question on RS SPL in the Subwoofer Equalization | Calibration forum; Noob question on RS SPL Hi, thanks a lot for your excellent software, it would take hours to calibrate a room without it. I just ...
Old 07-10-06, 12:08 PM   #1 (Link)
New Member
Alias: The Bu11
Loc: Florida
User: #1112
Since: Jun 2006
sammythebu11 is offline
Question Noob question on RS SPL
Hi,
I just plugged in a Radio Shack Digital SPL meter to my Mac and PC and as soon as I turn it on to 80db, REW shows 46db (or so), is this normal behavior? do I have a bad SPL meter? do I have a bad cable? when the SPL is not connected REW shows 3-4db. I have tried left channel and right channel with the same result.
I am hooking it up to the Line in of the computers using an RCA cable and a Stereo RCA to mini plug.
Thanks,
The Bu11
Old 07-10-06, 12:57 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: Noob question on RS SPL
Yes, it's normal. The 46dB is the noise level in the room. Go ahead and speak into the meter (it is a microphone) and watch the SPL respond.
Certainly when no cable or meter is hooked up you'll get a few dB from the card itself, I get about 10.
Go through the entire setup though to ensure your REW Program is calibrated to the meter....
Old 07-10-06, 02:39 PM   #3 (Link)
New Member
Alias: The Bu11
Loc: Florida
User: #1112
Since: Jun 2006
Thanks,
I'll give it a try tonight.
The Bu11.
Old 07-10-06, 05:30 PM   #4 (Link)
New Member
Alias: The Bu11
Loc: Florida
User: #1112
Since: Jun 2006
Ok,
I must be doing something wrong now, the SPL shows 75 on the digital meter but REW shows 67.5, am I doing something wrong? should I use the value on the meter to calibrate or should I use the value on REW?
Thanks for your help and patience with this rookie.
The Bu11
Old 07-10-06, 05:40 PM   #5 (Link)
Alias: brucek
User: #6
Once you've completed "SET MEASUREMENT LEVEL" and "SET INPUT VOLUME" and are in the "CALIBRATE" setup, REW asks for the reading from your actual SPL meter to be entered into the REW meter so that they match. After that's entered you will "SET TARGET LEVEL".... then you're ready to do an "AUTOMATIC MEASURE".
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
