REW ForumDiscuss Preparing for REW+BFD in the Equalization | Calibration forum; Preparing for REW+BFD Fast response ...... I hope you are getting some work done ... I need to soon. I didn't follow your ... |
Views: 2974 - Replies: 125
| | #51 | ||||
| Re: Preparing for REW+BFD Fast response ...... I hope you are getting some work done ... I need to soon. I didn't follow your 20, 40, 60, 80 ... are these the choices on the sub variable phase control? This leads me to ask one more question, can REW provide phase or "distance" at each of an array of sample frequencies? Bruce, I'm sure you are right that if an auto EQ room correction system falls short, it's going to be below ~100 Hz and more often than not, rooms will have severe problems down there. In a bit of experimenting with sub locations with a higher WAF rating, I did find some with a range of +10 to -15 db under 100 Hz that would take some powerful EQ to solve. And, frequencies at the peaks and valleys were different at each seat and no EQ system can solve that. Harrison | ||||
| | #52 | ||||
| Re: Preparing for REW+BFD I have an analog phase control on each sub, variable from 0 to 180. It simply has some dashes to represent where you are on the phase 'scale.' So the first big dash is 20 degrees, the second is 40, the third 60, etc. In between the big dashes...aw, here: http://av123forum.com/showpost.php?p=484648&postcount=141 ![]() | ||||
| | #53 | ||||||
| Re: Preparing for REW+BFD Quote:
Or you wait for the next version of REW in beta testing right now that has an RTA feature and adjust the phase live with the RTA running. Quote:
brucek | ||||||
| | #54 | ||||
| Re: Preparing for REW+BFD Trekari, It just occurred to me that the dip you are worrying about in the 90-95 Hz region is right about where a crossover might fall. What is your mains-subs crossover set at? If there is any phase problem between your subs and mains the dip should be wider, but still one has to wonder. | ||||
| | #55 | ||||
| Re: Preparing for REW+BFD I had the xover on the fronts at 80Hz, and the sub crossover was set to 180 actually. After my measurements of each front speaker/center on Friday I will set their xovers to where each makes sense and integrates with the subs the best. | ||||
| | #56 | |||||
Ethan also did a simple evaluation of the effectiveness of the Audyssey MultEQ, which claims to reduce ringing. His conclusion was that it was a mixed bag as far as dealing with extended low frequency signal decay, aka “ringing” or “modal ringing.” Since there seems to be a dearth of in-room time domain testing, other than these two, I’ve done some of my own (although I haven’t posted any results). After studying waterfalls ’til I’m bleary-eyed, I’ve found pretty much the same thing as Ethan, that actual in-room measurements show that it’s a mixed bag using an equalizer as a fix for extended low frequency decay issues. I compared multiple waterfalls (as alluded to here, you won’t get a true picture from a single sweep) of equalized response using what I’ll call “modal filters,” that REW recommended to improve ringing (which is what REW does when you run the “Find Peaks” routine), to the “smoothing filters” I like to use (i.e., simply EQing out peaks and nulls with no regard for any effect on ringing). What was apparent was that the modal filters improved ringing for some peaks REW had identified, but for others there was no improvement at all. Even then, the improvement waterfalls did show for modal filters was only apparent in the short-duration 300 ms window. When the window was lengthened to 600 or 1000 ms, any advantage modal filters showed over smoothed fully vanished. The overall trend was that modal filters had the effect of quickly attenuating decay in the short term (compared to smoothing filters), but only down to a certain level. In the long term, both sets of filters were showing comparable results (this despite the fact that most of the smoothing filters were set for boost!). Which is to say, there was no reduction in ringing. That’s one thing I have noticed here at the Shack where people (including myself) have posted graphs showing that an EQ filter improved ringing: They’ve all been short-duration 300 ms windows, not long-duration. You can clearly see this “fast attenuation but only to a certain level” effect with the first set of comparison graphs from Ethan’s Audyssey evaluation - note the region between 56 and 20 Hz. ![]() Ethan and John both maintain that narrow filters have the greatest effect on time domain. That’s one thing I have yet to evaluate at length, but intend to. Regards, Wayne | |||||
| | #57 | ||||
| Re: Preparing for REW+BFD Well, it turns out that BJC was exceptionally slow in shipping my order. Placed 2am Tuesday morning, is only supposed to ship out today. ![]() So unless I get the desire to do manual measurements, I won't be moving my PC into the living room until (at BEST) Friday, possibly Saturday, depending on when they arrive. I plan on doing sweeps of all 7 speakers individually with and without Audyssey, so those of you interested in the benefits of Audyssey will want to stay tuned for another sample. Secretly I'm also hoping that my in-room non-Audyssey sub response is a bit more suited for a house curve than the relatively flat post-Audyssey graph. So I have my own reason for running the comparisons, hehe. ![]() Last edited by Trekari; 01-31-08 at 03:02 PM.. | ||||
| | #58 | ||||||||||
It occurs to me that I said something stupid earlier about filters compensating room decay. One may want to adjust room decay but one doesn't want to eliminate it. Doing so would befuddle sensitive ears that expect a "real" room. I wonder though whether a filter that corrects a given peak or dip in frequency response will necessarily be altering the decay at those frequencies appropriately. I.e., is there a correlation between a dip in frequency response at a listening position and the room decay at that frequency. I'm thinking not. A reflection from a wall/ceiling near the sub can combine with the direct wave (as in Tekari's case) and cause quite a response dip, but that doesn't mean that there will be additional reflections that continue bouncing around the room at that frequency (that reflection may have come via the only solid surface in the room). If I'm right, any decay correction wouldn't necessarily be appropriate. Quote:
I wonder though, the ear must deal frequently with variations in decay. Decay may not be much of an issue if the ear/brain takes care of it. Unless maybe the decay problem is severe. I mean a boomy room is a problem, but beyond that maybe decay isn't much of an issue. Quote:
Best, Harrison | ||||||||||
| | #59 | |||||||
However, I did notice some sonic degradation with the modal filters (which were more numerous and narrower than I like to use). The uneven bass notes I complained about in the Hard Knee article returned. Quote:
Here are a few more graphs, this time from Ethan’s Traps vs. EQ face-off (the ones added after the fact). Again, the equalizer was not adjusted properly, which may account for why we don’t see the “fast attenuation” effect. But one thing's for sure, looking at the Traps graph, I don’t think anyone can say they got they get that kind of reduction of decay from equalization (although I don't think I want 17 traps in my living room!). ![]() ![]() ![]() Regards, Wayne | |||||||
| | #60 | ||||
| Re: Preparing for REW+BFD Convincing enough. Do I read these as running out to 518ms? I vaguely recall 600ms being an appropriate decay rate. Does that ring a bell? The 18-50 Hz range looks to be several seconds with traps and a bit less with the EQ. Higher frequencies are brought down very quickly by the traps and only modestly by the EQ. I wonder if the more uniform decay rate across the 18-322 region provided by the EQ isn't preferable to the longer decay at the low end and very short decay above about 50 Hz in the traps option. Does Ethan discuss that? If my recollection of 0.6 seconds is right, the EQ looks better. But, maybe that .6 isn't right. I think I'm lucky. My room is large, well broken up, lots of random absorbing surfaces, few opposing sizable parallel surfaces, etc. But, I'll check it with REW as soon as I master it. Right now it's telling me my "input" is too low and I can't get it up. If Audyssey does as well with decay as it does with frequency, I should be in good shape. Below are my before and after sub plots averaged across 10 measurement locations in a three-seat bubble. Each seat tested individually looks about the same before and after, so even though these are averages for the 10 measurement locations, they are representative of each seat. Vertical divisions are 5 db. Horizontal range is 20Hz and up. Before: ![]() After: ![]() Harrison | ||||
