How to make all this work (SPL to REW to BFD) help - Page 4 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss How to make all this work (SPL to REW to BFD) help in the Subwoofer Equalization | Calibration forum; How to make all this work (SPL to REW to BFD) help but not sure what a broader filter is ,but I will figure it out If that's the case you should ...
Old 08-08-06, 05:51 PM   #76 (Link)
Alias: brucek
User: #6
brucek is online now
Re: How to make all this work (SPL to REW to BFD) help
If that's the case you should take time now to read any sections of the BFD GUIDE and also your BFD user manual on bandwidth of filters.....
Old 08-08-06, 06:59 PM   #77 (Link)
Alias: rlammi
Loc: Roseville ,Ca
rlammi's Avatar
User: #1352
rlammi is offline
I am brucek ,I will have it figured out and get a graph reran to check out once i get all the filter adjustments corrected ,and I finally figured out what you ment
about playing around wit the filters, I didn't have the corrected box checked so it wasn't showing me the changes the filters made will tweak it and let you know .Thanks again brucek .
Sunfire Theater Grand 2 Processor
Adcom GFA-7700 Amplifier
Yamaha cd changer
Sony dvd changer (needs upgraded)
Vizio 50'' Plasma TV
Klipsch center channle (will be upgraded)Audax 3-way is coming
GR-Rsearch AV/3'S mains
JBL in wall for surrounds
Behringer A500 for Subwoofer amp
4-12's Infinite Baffle for subwoofer
Behringer BDF for sub EQ
If it is to loud ,my wife must be home
Old 08-08-06, 09:13 PM   #78 (Link)
Exterminated!
Alias: ThomasW
User: #22
ThomasW is offline
Broader filter= wider bandwidth filters like 120/60 if you're using a BFD. Make 'shelving' filters to pull down the higher frequencies. I know Bruce is using a similar filter for his settings. I don't remember exactly where he discusses it's operation.
Old 08-09-06, 09:22 AM   #79 (Link)
Alias: rlammi
Loc: Roseville ,Ca
rlammi's Avatar
User: #1352
rlammi is offline
Thomasw or brucek
what is a shelving filter ,I have heard it before .I finally understand the wider or broader filters ,I am going to reinput the data and then play with the filters a little more and then input them into the BFD and retake the measurement and then I guess it will be tweaking from there .I will repost once I get a chance to rerun reqw and see were any more adjustments are needed .Thanks all for the input and advice .I am ready to put a DONE stamp on this thing .
Yamaha cd changer
Old 08-09-06, 11:07 AM   #80 (Link)
Exterminated!
Alias: ThomasW
User: #22
ThomasW is offline
This is an example of a shelving filter
These are the filter settings used to create it...
Old 08-09-06, 11:39 AM   #81 (Link)
Alias: rlammi
Loc: Roseville ,Ca
rlammi's Avatar
User: #1352
rlammi is offline
Thanks Thomasw ,how do you know were to put the filters? Yours is an example is it close enough for me to use or would I need something different ? and I don't know if you have seen my first graph ,but it almost takes all 12 filters in reqw .Would adding the shelving filter cut down the number of filters I would need in the ower frequencies ? If I am reading this type of filter it will bring the lower frequencies down so there should be less filters needed .I will try and rerun it tonight and input the filters and try and take another reading and post it so everyone can see .Thanks all ,Ron.
Yamaha cd changer
Old 08-09-06, 12:29 PM   #82 (Link)
Alias: brucek
User: #6
rlammi,
You're getting way off track here.
Without filters, your raw measurement is quite good (as shown below) and in my opinion you don't need many carefully selected filters to correct it. You don't need a shelf filter.
Simply do a raw measurement without any filters in the BFD and REW and then follow step by step the procedure I outlined for you.
In fact you can simply attach your measurement.mdat file and I'll suggest some filters for you to try. It's always better though if you do it and learn yourself....
Old 08-09-06, 12:54 PM   #83 (Link)
Alias: rlammi
Loc: Roseville ,Ca
rlammi's Avatar
User: #1352
rlammi is offline
okay brucek, I will run one more raw graph and then go threw the filter setup that you outlined and go from there. One final question can I use the first raw reading to get the filter readings or should I run another ?Thanks bruce will get the reading the the next day or so .Again many thanks I am finally understanding the process much better now .Ron
Yamaha cd changer
Old 08-09-06, 01:23 PM   #84 (Link)
Exterminated!
Alias: ThomasW
User: #22
ThomasW is offline
I'm certainly not suggesting he needs to copy the filter I posted. It's just an example of how they're made.
Unlike a standard 'portable' sub, IB subs don't naturally roll-off from the acoustic filter created by 'box'. So.....
Using his filter choices; 20hz +8, and 25hz +5, any music or sound effects with significantly low bass will cause the drivers to slam into the formers.
Old 08-09-06, 01:25 PM   #85 (Link)
Alias: brucek
User: #6
If you saved it in a xxx.mdat file, then simply use it again to create your filters off-line with REW - no need to take another reading.
Then once you enter your filters into the BFD, take a new raw reading (be sure any filters in REW are shut off) and check the results of your work...
Old 08-09-06, 01:27 PM   #86 (Link)
Alias: brucek
User: #6
Yep, and I completely agree.......
Old 08-09-06, 01:47 PM   #87 (Link)
Alias: rlammi
Loc: Roseville ,Ca
rlammi's Avatar
User: #1352
rlammi is offline
Thanks bruecek and thomasw
I will rerun all the filters and take another reading and repost .Thanks for all the patience .
Yamaha cd changer
Old 08-10-06, 09:10 PM   #88 (Link)
Alias: rlammi
Loc: Roseville ,Ca
rlammi's Avatar
User: #1352
rlammi is offline
First off I would like to say thanks t o everyone involved with this brucek,johnm, sonnie and the shack and to thomasw at the cult (for getting me into the I/B project). This has really been a learing expierence with the BFD REQW and the building of this subwoofer .One forum led to another forum and there are a great bunch of people on both .I have gotten a lot of help with the filter I was trying onmy own but I wasn't really getting it I kind of do now .So here is my latest graph and it looks pretty good I thought I would need most of the filters to get it to come close to the target sor here it is and I have to thank Thomasw over at the Cult for the settings here it is and I am going to work on another setting of my own to see how I can adjust it for music I need a little more punch .Played the Eagles and some other stuff sounded great but would like a little more punch or I may need to get use to it .As for movies went right to WOTW and sounds awesome .So per the wifes request we are watching KONG tonight .here is the graph again THANKS TO EVERYONE , Ron.
Yamaha cd changer
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177
