REW Forum
How to make all this work (SPL to REW to BFD) help
Discuss How to make all this work (SPL to REW to BFD) help in the Equalization | Calibration forum; How to make all this work (SPL to REW to BFD) help Hello everyone , Have gotten spl readings from 10hz to 162hz is there a way to put them into a ...
Views: 3182 - Replies: 87
Old 07-08-06, 06:14 PM   #1
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
Hello everyone ,
Have gotten spl readings from 10hz to 162hz is there a way to put them into a file and import them in to rew , I know I will eventually have to take new readings as I adjust the bfd ,but this is all a little confusing for me any help is greatly aappreciated .Thanks in advance ,Ron.
Sunfire Theater Grand 2 Processor
Adcom GFA-7700 Amplifier
Yamaha cd changer
Sony dvd changer (needs upgraded)
Vizio 50'' Plasma TV
Klipsch center channle (will be upgraded)Audax 3-way is coming
GR-Rsearch AV/3'S mains
JBL in wall for surrounds
Behringer A500 for Subwoofer amp
4-12's Infinite Baffle for subwoofer
Behringer BDF for sub EQ
If it is to loud ,my wife must be home
Old 07-08-06, 06:49 PM   #2
Alias: brucek
User: #6
  brucek is online now
Re: how to make al this work (spl to rew to bfd) help
Yes, select FILE and Import Measured data. The measured data must be in the form of frequency and then a space and then the SPL reading and be labelled with a .txt extension.
i.e
10 90
12.5 95
You must enter the correct cal file into REW for the type of SPL meter you're using. There are three types and all three files are stored on the site.
Be sure to use the graph setup recommended here
Why not simply use REW to take the measurements? I know you have a computer.
edit: oh ya, there's a bug. You must enter the first entry as a dummy. So if your first real entry is 10 90, then before that enter 8 90 as the dummy. How's that for confusing...
i.e.
8 90
10 90
12.5 90
etc
Old 07-09-06, 10:48 AM   #3
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
brucek ,
How do you hook the spl meter up to the computer? I wil try later today. I did a manual graph and there are some big dips not sure what they mean ,but will keep trucking along until I get this sub dialed in. thanks and I will try to import them in.
Yamaha cd changer
Old 07-09-06, 12:48 PM   #4
Alias: brucek
User: #6
As shown here in the REW help file.
Notice the soundcard adapters are stereo..
I assume you took your readings with C-weighting turned on?
Old 07-09-06, 03:02 PM   #5
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
Brucek
Thanks I will get some adapters and try it both ways to se how close I was and yes I had the c weighting on ,thanks again.
Yamaha cd changer
Old 07-11-06, 12:30 PM   #6
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
Hello every one.
I have take readings ,just a trial here until I get some adapters to run rew through the computer to take the next set of readings ,how do i up lad an image of the first graph ? Thanks for all the help .
Yamaha cd changer
Old 07-11-06, 12:40 PM   #7
Alias: brucek
User: #6
See here
Old 07-11-06, 02:22 PM   #8
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
Hey brucek , thanks I finally just put them on the hosting service I have all the other pictures on ,the graph looks ugly so I may have done something wrong I will retake all the measurements with rew when i get the adapters so let me know what I need to fix or do with this graph. Thanks again. Ron
http://http://community.webshots.com/user/rlammi100
Yamaha cd changer
Old 07-11-06, 02:56 PM   #9
Alias: brucek
User: #6
OK, here's your graph. Your link is bad, but I deciphered it.... :raped:
There are some issues here.
The horizontal axis must be from 15Hz to 200Hz since we are only interested in subwoofer response. It will then increase the resolution of the area of interest.
You are taking measurements at too high a level. Try and average around 80dBSPL as shown in the target..
Did you compensate for the inaccuracy of the RS SPL meter with the correct calibration files here loaded into REW?
I doubt the spikes are realistic. There's a problem with the measurements there I suspect.
Post your graphs if possible using the link I provided in my previous post so everyone can see them.
Old 07-11-06, 03:51 PM   #10
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
brucek , the previous link is closed .I will try the link again, I tried to set every thing at 70db ,but I guess I had it set to high .Is it easier to control through
REW or will it still take some work? I thought it loked funny ,I did it manually on graph paper and the peaks didn't look anything like what came up in rew so maybe in the transfer of the data I did something wrong ?Anyway here is the link again ,I tried the previous link but it shows it is closed .http://community.webshots.com/user/rlammi100
Yamaha cd changer
Old 07-11-06, 04:00 PM   #11
Alias: brucek
User: #6
Yeah, that link works. It's just that everyone likes to see pictures because it's so easy to comment on. Try and see if you can figure out how to make an attachmenet here at the site for the future.
Is it easier to control through REW or will it still take some work?
It's quite easy to control through REW once you have it all hooked up with the correct cables and adapters.
Post your text results and show us what you have. (What model of the three SPL meters do you use?)
Old 07-11-06, 07:00 PM   #12
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
I have the new digital meter and that is what I used ,but I didn't convert anything before I imported it into ,should I have ? The graph I did was on graph
paper done manually with a pen and a ruler .I can add the number file if that is what you mean ,Don't worry as soon as I get a change to play with this a little I will get the hang of it .Thanks again brucek.
Yamaha cd changer
Old 07-11-06, 08:00 PM   #13
Alias: brucek
User: #6
No, you did good. Except you copied down a few of the values wrong at 487Hz and 117Hz (as shown in the insert for 487Hz below). I corrected these and have posted the graph. I had to use REW to manually subtract a wholesale 15db from all your values to get a look at what it would be like near the target.
I can't believe how much you're outputting at those low frequencies. Amazing, must be shaking the house. You need a BFD.
I think the graphing will be much more accurate when you get REW going. It's a good start though to get yourself educated on this stuff.
This shows one of the two errors in your text data causing the spikes.See the double entry of 48Hz. I corrected it and the one at 117Hz.
Old 07-11-06, 08:51 PM   #14
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
Thanks brucek,figures I would have doubles up numbers ,I inputted those about three times .Yes the wife thinks it is a little loud at times but you never know when you need the power or the ability to go low .Thanks for looking over my readings .I will try and get all the adapters I need so I can get some figures some time this weekend ,trying to go camping for a few days so it may not be until the first of next week .I already have the bfd hooked up and ready once I figure out were I need to cut or add boost .The corrected graph looks better now I know why the paper graph looked better .Thanks again brucek will be back once I get rew hooked up to the bfd .
Yamaha cd changer
Old 07-14-06, 03:49 PM   #15
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
Hello everyone trying to get rew going have all the cables set ,but don't know what to do to test the system and record a graph.I have been reading the help files but I am lost please help .Thanks in advance .
Yamaha cd changer
Old 07-14-06, 05:06 PM   #16
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
okay I took a few readings with the spl meter and rew ,these may or may not be right I took them with the different sine wave,pink ,and other tests any advice .Thanks Ron
Yamaha cd changer
Old 07-14-06, 05:38 PM   #17
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Looks like you are measuring either with a loopback connected (i.e. you have the output linked directly to the input and are measuring that) or you have the input set as "What U Hear" or similar, which also simply records what is being played out.
Old 07-14-06, 08:37 PM   #18
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
I hooked eveything up like brucek's photo showed ,but I will double check and repost the results .Thanks Ron.
Yamaha cd changer
Old 07-14-06, 08:52 PM   #19
Alias: brucek
User: #6
The suggestion by John is that if the error isn't caused by an external mechanical loopback, then you must have the soundcard in software loopback mode.
This is evidenced by the fact that the graph is showing an exact mirror of the SPL meters calibration file. If I shorted the output of the soundcard to the input, this is what I would see. You're not reading the SPL meter at all.
Check that the soundcard doesn't have a setting that puts it in a monitor mode. What kind of soundcard do you have?
Also a minor point, but normally we use a vertical graph axis of 45dB to 105dB and a horizontal axis from 15Hz to 200Hz. Use the graph axis icon for this setup.
Old 07-15-06, 12:17 PM   #20
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
That makes sense ,if rew is just copying down what it puts out ,with the way I had it hooked up I could hear all the sound from the subwoofer ,so it has to be with the sound card ,I don't know what kind it is just has a line in and out to the speaker or mic .I will try again and see what happens ,I thought those graphs looked to clean ,and at a funny angle ,Thanks all will report when I have a chance to rerun them
Ron.
Yamaha cd changer
Old 07-17-06, 04:19 PM   #21
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
It may be the sound card I have that isn't letting me use rew to take the reading.have been working on the rew with the imported data ,and here is what have first one is with the filtes applied ,then without c-weight comp when the data was imported and then with the c-weight com any help would be appreciated ,thanks Ron
Yamaha cd changer
Old 07-17-06, 06:52 PM   #22
Alias: brucek
User: #6
Do you have the proper RS meter calibration file loaded?
Have you done a soundcard calibration and saved the file?
I'm having a bit of trouble understanding what you're doing in your graphs. Set the axis limits of all graphs with a vertical axis of 45dB to 105dB and a horizontal axis from 15Hz to 200Hz.
I would concentrate on getting REW to work properly and leave the manual measurements. You'll get much more accurate results.
What type of soundcard do you have?
Old 07-18-06, 09:24 AM   #23
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
brucek ,I am not sure what kind of sound card ,it looks generic maybe what came with the computer ,and the computer isn't anything special.And I haven't done anything for the calibrations .Were do I put those in, before I import the readings?I will readjust the axis next time I run it .I also am have a hard time understanding what the graphs mean also ? I will reread al lthe rew help text and see were I am .ON the sound card issue I have tried hooking it up to the line and the mic and the meter is reading one thing and rew is reading another .
Thanks brucek , I will rerun the readings once I figure out what calibration files I needs .
Yamaha cd changer
Old 07-18-06, 09:47 AM   #24
Alias: brucek
User: #6
There's really no use in posting graphs until you have all the problems with REW solved.
The first step is ensuring you have it connected correctly and that you have your soundcard type selected in REW.
Let's solve that puzzle first.
The picture below is the recommended hookup. Let's get that part out of the way before we move on.
Note the stereo adapters that plug into the soundcard. One connects to the LINE-IN and one connects to the LINE-OUT. Note we are using only the right channel on the adapters and not the left....
Is this the hookup you have exactly, including the correct adapters?
If so, the next thing you need is the soundcard information so you can select it in REW.
In Windows go to START / CONTROL PANEL
In CONTROL PANEL double click SOUNDS and AUDIO DEVICES
Select the AUDIO TAB.
The sound play back and sound recording entries will show the name of the default audio card being used. Remember this name, since you'll need to select it in REW for its playback and recording entry.
Is there anything so far that you don't get? No use moving on until that's complete..
bruce
Old 07-18-06, 10:29 AM   #25
Alias: rlammi
rlammi's Avatar
Loc: Roseville ,Ca
User: #1352
  rlammi is offline
brucek ,
I purchased those same adapters but they both won't plug in at the same time .I tried using the headphone out on the front of the computer .Then I went and got strait rca to 1/8th adapters so I could plug them both in ,still the same thing I is reading what rew is putting out ,the spl meter is reading higher .I will recheck the sound card info and let you know and I won't try anything else until I get that working ,sorry for wasting space on the forum .
Thanks again ,Ron.
Yamaha cd changer
