Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > REW Forum
Register
REW Forum
My first REW graph, do I need BFD
Discuss My first REW graph, do I need BFD in the Subwoofer Equalization | Calibration forum; My first REW graph, do I need BFD Just done my first graphs of my room with my tiny M&K KX10. I don't need it ...
Old 02-03-08, 07:29 PM   #1 (Link)
New Member
Alias: henry
Loc: england
User: #16369
Since: Feb 2008
henry1234 is offline
I don't need it to go low or loud as I have children & neighbours. I just want a smooth response so I hear a nice sound.
From my ears I was aware of a peak, it sounded fun for a little while in the new room but obviously not fun enough as I am now on this forum at 1:30am.
I have to sit against the back wall, hence the 50-70hz peaks.
Can a BFD help smooth out this graph, I have a chance to pick one up cheap tomorrow?
The sub is literally just above minimium volume setting on the dial.
Old 02-03-08, 09:02 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: My first REW graph, do I need BFD
You're being unkind to yourself by using such an exaggerated vertical scale.
Normally we use 45dB-105dB as the standard. This allows for a 75dB target measuring level with a +/- 30dB swing.
It's also best to measure the sub with the mains disconnected to determine the peaks caused by the sub alone. Once the sub is equalized, then the mains are added to get the best transition at the crossover.
Anyway, for sure the peak you have can be smoothed with a BFD very easily. You might also try moving your sub around a bit if possible to get the best response possible before equalizing....
Old 02-04-08, 04:04 AM   #3 (Link)
New Member
Alias: henry
Loc: england
User: #16369
Since: Feb 2008
thanks,
I've changed the scales.
This was with only the sub connected, direct to the soundcard.
It normally connectes to my Lexicon DC-2 with crossover set to 120hz with M&K K17's as front speakers.
Old 02-04-08, 07:39 AM   #4 (Link)
Alias: brucek
User: #6
Yeah, you have a peak between 50-60Hz that could be easily eliminated. It's useful to look at your sub response 'in-situation' with the receiver and the crossover you normally use to see how it looks. An equalizer would connect between the sub out of the DC-2 and the sub amp, and is fairly easy to set up. You already know how to use REW.
Old 02-04-08, 09:38 AM   #5 (Link)
Alias: Wayne
Loc: Katy, Texas
Wayne A. Pflughaupt's Avatar
User: #8
Henry,
What kind of sub is this? Is it a budget model with a small driver? Judging from the fact that it rolls out fairly hard below 50 Hz, a relatively high frequency, that would be my guess.
If that’s the case, you’ll want to be very careful using the BFD, because equalizing a sub ends up placing additional demands on it. So you really need a subwoofer with headroom to spare.
Don’t mean to put down your equipment – just don’t want to see you damage it! The little 8” M&K sub I have for my computer speakers complained loudly with the low notes after I put a BFD on it!
That said, if your normal operation is at lower volumes, as you indicated, you should be all right.
Old 02-04-08, 01:23 PM   #6 (Link)
New Member
Alias: henry
Loc: england
User: #16369
Since: Feb 2008
yes it is a small relatively small budget model:
http://www.progressive-av.com/produc..._specsheet.pdf
levels will always be low so I hope it's worth getting the BFD.
Old 02-06-08, 01:50 PM   #7 (Link)
Alias: Wayne
Loc: Katy, Texas
User: #8
If your crossover point was the usual 80-90 Hz, I’d say you look pretty good and you don’t need a BFD. However, since you’re dividing at 120 Hz, the BFD could smooth out that raggedness between ~75-120 Hz. If you don’t try to boost the bottom end (below 50 Hz), and limit adjustments elsewhere to maybe no more than +/- 6 dB, you should be fine. If you overdo it, you’ll know because the sub will make all kinds of rude noises.
As an aside, I notice the spec sheet you linked said the KX extends to 35 Hz. M&K seems to exaggerate their low freq specs – my 8-incher was supposed to be good to 25 Hz; didn’t even get close.
You may not post new threads, nor post replies, nor post attachments, and you can not edit your posts.
vB code is On, Smilies are On and [IMG] code is On
Similar Threads
got my bfd - first graph i need help miker916 REW Forum 5 03-04-07 05:54 AM
First REW graph attempt - HSU3.3 camtah REW Forum 11 03-03-07 11:28 PM
New to the Shack, my first BFD graph :) O_ROD REW Forum 20 11-13-06 12:52 PM
Diy Sub REW Graph c3ham REW Forum 6 09-16-06 02:09 PM
REW Graph - Before & After BFD - SVS PCI 20-39 Dent REW Forum 16 06-03-06 08:53 PM
Video Products, Inc. Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
Search Engine Friendly URLs by vBSEO 3.1.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173
