Using REW for individual driver measurements? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Using REW for individual driver measurements? in the Subwoofer Equalization | Calibration forum; Using REW for individual driver measurements? So, I've got a 4-way active system using a PC-based DSP crossover: http://www.thuneau.com/allocator.htm I already use REW for eq of ...
Old 02-07-08, 11:59 AM   #1 (Link)
New Member
Alias: Desmond
User: #1928
Since: Aug 2006
djsixbillion is offline
I already use REW for eq of a sub in a separate HT system, and have now been attempting to use it for individual driver measurements that can be imported into the above-mentioned program. REW has the option to export a measurement as a text file, which I then open and remove all the header information from, so that I'm left with just two columns of data, frequency and SPL. I then rename this to .frd (standard file format for frequency response data), but for some reason the crossover program won't open these files.
Anyone know of a good way to get .frd files out of REW? Or are there any other free/cheap measurement programs you could recommend?
Thanks,
Desmond
Old 02-07-08, 12:17 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Using REW for individual driver measurements?
Isn't the only difference between an .frd and a .txt file the phase information (freq magnitude phase)? I don't know the impact of the phase information, but if you simply want the program to read the .txt file, add a 0.000 to each entry and then rename the file to frd. You could use excel to add the zeros for you....
Old 02-07-08, 01:28 PM   #3 (Link)
New Member
Alias: Desmond
User: #1928
Since: Aug 2006
That's a good idea, I'll try it tonight.
Has anyone else used REW for this kind of thing? I'd be interested to hear any tips or tricks people might have for getting good, accurate measurements.
Old 02-08-08, 01:33 AM   #4 (Link)
Alias: Mike Bentz
Loc: Chicago
DrWho's Avatar
User: #2782
Since: Sep 2006
DrWho is offline
You can export the impulse response and then process the data using Praxis...not sure if Praxis can help you out with the file format, but it might be worth looking into...
-Mike Bentz
~It's all about compromise~
"It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!"
Old 02-08-08, 12:10 PM   #5 (Link)
New Member
Alias: g3kko
Loc: Green Bay-ish, WI
User: #1457
g3kko is offline
You could also extract the phase information using the Frequency Response Combiner provided by the FRD Consortium. That will build your minimum phase information. Google will find it.
Similar Threads
What am I doing wrong? First REW Measurements Kruppy REW Forum 14 11-11-07 12:06 PM
Full Range Measurements with REW - What Equipment? Drizt REW Forum 19 07-21-07 11:50 PM
Noobie with REW help with measurements rm1759 REW Forum 14 06-07-07 05:18 PM
Need help with REW - can't get reasonable measurements Tobias REW Forum 95 04-24-07 11:00 AM
REW v. SMS Measurements Josuah REW Forum 13 08-22-06 06:45 PM
Mach 5 Audio
