| REW Forum Noob question on RS SPLDiscuss Noob question on RS SPL in the Equalization | Calibration forum; Noob question on RS SPL Hi,
thanks a lot for your excellent software, it would take hours to calibrate a room without it.
I just ... |
Views: 691 - Replies: 4
| Hi, thanks a lot for your excellent software, it would take hours to calibrate a room without it. I just plugged in a Radio Shack Digital SPL meter to my Mac and PC and as soon as I turn it on to 80db, REW shows 46db (or so), is this normal behavior? do I have a bad SPL meter? do I have a bad cable? when the SPL is not connected REW shows 3-4db. I have tried left channel and right channel with the same result. I am hooking it up to the Line in of the computers using an RCA cable and a Stereo RCA to mini plug. Thanks, The Bu11 | ||||
| | #2 | |||||
| Re: Noob question on RS SPL Quote:
Certainly when no cable or meter is hooked up you'll get a few dB from the card itself, I get about 10. Go through the entire setup though to ensure your REW Program is calibrated to the meter.... brucek | |||||
| | #4 | ||||
| Re: Noob question on RS SPL Ok, I must be doing something wrong now, the SPL shows 75 on the digital meter but REW shows 67.5, am I doing something wrong? should I use the value on the meter to calibrate or should I use the value on REW? Thanks for your help and patience with this rookie. The Bu11 ![]() | ||||
| | #5 | ||||
| Re: Noob question on RS SPL Once you've completed "SET MEASUREMENT LEVEL" and "SET INPUT VOLUME" and are in the "CALIBRATE" setup, REW asks for the reading from your actual SPL meter to be entered into the REW meter so that they match. After that's entered you will "SET TARGET LEVEL".... then you're ready to do an "AUTOMATIC MEASURE". brucek | ||||
