requirements for REW - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss requirements for REW in the Subwoofer Equalization | Calibration forum; requirements for REW hi folks first post here i just downloaded REW and since it seems to be the only analyzer-app running on ...
Old 04-24-06, 08:19 AM   #1 (Link)
New Member
Alias: chris diggelmann
User: #79
seedee701 is offline
hi folks
first post here
i just downloaded REW and since it seems to be the only analyzer-app running on mac, i have great hopes in it.
from what i've seen it's exactly what i was looking for. i'm in the process of tuning my room and therefore need only the analyzing function of the software (for now...)
however i can't make the app to work, it just doesn't open doubleclicking on it. is there anotherway to start the applet? tried the darwin-terminal, tried browsers didn't work either.
all .jars in same folder as stated in the helptxt.
here my configuration:
mac g4 dual 1.25, 1.5gig, OS 10.4.6
i also failed updating the recomended java-core, apparently my version is newer. j2se 5.0 is the current java-core
help is greatly appreciated
Old 04-24-06, 08:26 AM   #2 (Link)
New Member
User: #79
Re: requirements for REW
is REW supposed to work with ANY soundcard? i read of people using USB cards. ... are firewire and PCI-soundcards supported, such as presonus firepod or motu2408 PCI system
Old 04-24-06, 08:36 AM   #3 (Link)
Loc: Lower Alabama
Welcome to the Shack, Chris... JohnM should be around pretty soon to help you figure this out.
Old 04-26-06, 04:30 AM   #4 (Link)
Alias: Mike
Loc: Seattle, WA
User: #34
genesis471 is offline
Sorry about this but I just added a new post regarding the same issue!
I will hang out a while and see what the solution is! I'm sure there will be more Mac users that visit this site that are interested in using the REW as well.
Fingers crossed!
Mike
Denon AVR3805, Denon 3910, BFD1124, Axiom M60 fronts, QS8 rears, VP150 center, M&K sub, Yamaha sub in back.
Old 06-02-06, 07:57 AM   #5 (Link)
New Member
Alias: chrisl
Loc: France
User: #874
Since: Jun 2006
chrisl is offline
Hello,
I'm also a Mac user.
The application seems to run fine on my configuration:
mac g4 dual 1.0, 1.75gig, OS 10.4.6.
Double clicking on "RoomEQ_Wizard_obf.jar" icon launches the app.
But I would like to use REW with a (external) audio interface, in my case MOTU 2408 mk3 with a PCI-424 card.
In REW options, I only have Java sound audio engine avalaible, and this uses the built-in mac audio, wich is not best quality ...
Does anyone knows how to use external audio ?
Thanks a lot in advance.
Chris
Old 06-02-06, 08:05 AM   #6 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Hi Chris,
The JavaSound Audio Engine should use the default audio interface offered by the OS, if there is a Mac equivalent of the Windows control panel setting for the preferred audio interface this might do the trick.
Old 06-02-06, 08:48 AM   #7 (Link)
New Member
Alias: chrisl
Loc: France
User: #874
Since: Jun 2006
chrisl is offline
Thanks JohnM !
I think you're right. There on MacOs the Audio/Midi configuration app which sets the defauft audio ins and outs.
I'm not in my studio just now to test it, but I think it's the solution. I'll tell you if it's OK when tried.
Thanks again.
Chris
Old 06-04-06, 02:15 AM   #8 (Link)
New Member
Alias: chrisl
Loc: France
User: #874
Since: Jun 2006
chrisl is offline
OK !
REW tested with MOTU 2408 interface. It works !
Thanks again ...
Chris
Old 06-05-06, 04:26 AM   #9 (Link)
New Member
User: #79
chrisl wrote:
OK !
Thanks again ...
Chris
where could choose the 2408? does it show in the REW or i just need to select the OSXjava-thing there and chose motu in the audio-midi control panel??
thanx for you help
Old 06-05-06, 06:26 AM   #10 (Link)
New Member
Alias: chrisl
Loc: France
User: #874
Since: Jun 2006
chrisl is offline
Yes, choose the OSXjava-thing, after you had choosen MOTU in the audio-midi control panel.
Don't forget to choose 44.1k in the soundcard sub-menu in REW.
Whith that, I got the audio generator output on my 2408.
But I still have problems to get the correct input from 2408 in REW. If you get good results seedee701, tell me...
thanks
Old 06-27-06, 10:21 AM   #11 (Link)
Alias: Jackie
Loc: I ain't tellin ya!
User: #1074
Since: Jun 2006
JackieTreehorn is offline
hi guys,
I have been able to open the program fine and do some preliminary tests but the program keeps crashing on me and as most of you mac users know you have to start all over every time you restart the program. Anyone else experiencing this or have any suggestions? I have the latest Java updates. imac G5 1.8ghz OSX 10.46
Also i obviously havent done enough reading here but if someone knows of a thread that discusses what is the best method (cables, connectors) to hook up the spl meter as well as connecting to my receiver?
Ill go take a look around now
Thanks
Old 06-27-06, 01:42 PM   #12 (Link)
Alias: Jackie
User: #1074
Since: Jun 2006
Well I bet there are some other mac apps similar to this one in the below link that are a little less professional. I just found this one doing a quick search in google maybe there are some others for macs out there
http://mixonline.com/mag/audio_metri...abs/index.html
Old 06-27-06, 03:18 PM   #13 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Hi Jackie,
Would you mind looking in the diagnostic logs (location is shown in the REW Help -> About... dialog) and see if the log files have any info on what is causing the crashes? If they do, please email me the files.
P.S. Fuzzmeasure is an OS X app that is cheaper than the one you linked and looks very good: http://www.supermegaultragroovy.com/...s/FuzzMeasure/
Old 06-27-06, 05:06 PM   #14 (Link)
Alias: Jackie
User: #1074
Since: Jun 2006
First let me say thanks John for making the software available in the first place. That should have been my first post. Hope I didnt come across as making it sound like I didnt appreciate it. Thanks for the other link I will check it out too.
Im not sure how many mac users are in here, is there a mac specific section in the forum?
As far as the log files I will try and run the app and generate some. As a completely new user who hasnt read through all of the great info here I have a lot to learn.
Thanks for your time and I will let you know what I see in the log files.
Cheers
Old 06-27-06, 05:56 PM   #15 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Not many Mac users that I know of. REW seems a bit flaky on the Mac, which makes a mockery of the "write once, run anywhere" ethos of Java. Apple have their own platform-specific audio classes and provide minimal support for Java's built-in audio classes, unfortunately. At some point I'll beg, borrow or steal a Mac for a while and see if I can get it to run more smoothly, if I can adapt myself to that funky Mac lifestyle
Old 06-28-06, 06:32 AM   #16 (Link)
Alias: Jackie
User: #1074
Since: Jun 2006
OK John I sent an email with the error info let me know if you didnt get it.
Thanks.
Old 06-28-06, 08:29 AM   #17 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Got your email, thanks. The files roomeq_wizard6.log.txt etc are the REW log files, they are a rotating set where roomeq_wizard0.log.txt is the latest, roomeq_wizard1.log.txt is from the previous time the app was run etc. The other files you sent from MacintoshHD/Users/YourUserName/Library/Logs/CrashReporter and MacintoshHD/Users/YourUserName/Library/Logs/Java are generated by the OS in response to crashes within Apple's Java Virtual Machine. Not a lot I can do about those, it should not be possible for an app to do anything that crashes the JVM. Best thing there is to send them to Apple in the hope they will fix the JVM bug in a future Java update.
Old 06-28-06, 04:11 PM   #18 (Link)
Alias: Jackie
User: #1074
Since: Jun 2006
Ahh I see that makes a lot more sense than the way I wrote it in my email. So that means your application "itself" is running fine with no problems since there is no additional text in the log there. I have been sending apple a bunch of the errors so maybe if I keep at it someone will look at it.
Thanks again for taking the time to look at it all. I have been able to run a few tests but Im still learning, and have only been able to get a general curve for my sub.
When people are posting their response curves is that normally with 1/3rd oct. smoothing or 1/1 or what?
Im not sure if Im sending a clean enough signal the way I had everything wired up but here is a general idea of what Im getting with my pb10isd and some pics of my space as well. All tile not even any area rugs yet. So lots of harsh reflections at the moment. I still think Im going to have to return the pb10 and go with a lrager model.
Feel free to give this newbie some comments if my graph looks way off.
hmmm my attachments are too big Ill just post em at my pic site.
http://www.pbase.com/livverlips/stereo_shhhhhhtuff
Old 06-28-06, 04:26 PM   #19 (Link)
Alias: Tonio
Loc: San Diego
User: #1164
Since: Jun 2006
Tonio is offline
we're funkay, we're funkay LOL
I also have some freezing.
Spectraffo is cool but $800? woah, I did use teh demo for some measurements a while back. Now they don't post a demo anymore
Old 06-28-06, 06:37 PM   #20 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
No smoothing needed for the low frequency, look like valid measurements so all seems to be OK
Old 01-11-08, 08:27 AM   #21 (Link)
New Member
Alias: jean c
Loc: Oisterwijk, Netherlands
User: #15371
Since: Jan 2008
jeancoum is offline
Here's another Mac Newb from The Netherlands. Just started, in REW and in this forum, both of which are great, I think. I want my room optimized (hard surfaces, loads of echoes etc) with sound absorbers and diffusers. This app should be the killer for me!!
The app appears to run fine, but I can't get past the first hurdle: calibrating my soundcard Edirol UA-3d (which normally works fine in both playback I-Tunes and in recording albums). When I open the Settings-window to calibrate the soundcard, and click the Measure-button, I get a pop-up, that titles 'Unable to take SPL reading' with the following message: 'SPL meter audio input not available. This has probably to do with the strange message at start-up: 'No input mixers available supporting PCM-SIGNED 48000.0Hz, 16 bit, stereo, 4bytes/frame, little endian'. I can bypass this message and REW starts fine.
Sample rate is at 48, and not at the advised 44,1, because the app crashes if I try to change it. Input channel is Right, so my loop goes from line-out right to line-in right. Output device is Default device, and it is properly selected (from what I can tell) in my system preferences.
Please help.
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
