REW Forum
Can you use REW without calibrating your soundcard?
Discuss Can you use REW without calibrating your soundcard? in the Equalization | Calibration forum; Can you use REW without calibrating your soundcard? I ask because I cannot calibrate my soundcard. I posted my problem a few months ago and received several responses ...
Views: 494 - Replies: 1
Old 02-07-08, 03:53 PM   #1
Alias: FS
Loc: USA
User: #10839
Since: Aug 2007
  Frank_S is offline
I ask because I cannot calibrate my soundcard. I posted my problem a few months ago and received several responses here in this thread.
http://www.hometheatershack.com/foru...lp-needed.html
Old 02-07-08, 03:58 PM   #2
REW Author
Owner
Alias: John
JohnM's Avatar
Loc: UK
User: #2
  JohnM is offline
Re: Can you use REW without calibrating your soundcard?
Yes, you can use REW without calibrating the card, but not being able to calibrate tha card is usually a symptom of a problem that would also mean it would not be possible to get valid measurements. In your case, not being able to get a line input working but getting something from the mic level input on your pro card, may as well try taking some measurements and post the results (or the .mdat file from a measurement) and we can see whether it has worked.
