| REW Forum Questions on REW..Discuss Questions on REW.. in the Subwoofer Equalization | Calibration forum; Questions on REW.. And I cannot find where to disable this, so I can run direct Line In.
I'm confused how you were ... |
| | #26 (Link) | ||||
| Re: Questions on REW.. Quote:
You have to find what has placed the card in "monitor loopback" mode and disable it, becuase there is really no other way to use REW.......... brucek | ||||
| | #27 (Link) | |||
| Re: Questions on REW.. I will work on it more tonight. I will retrace all of my steps and try to find out where I am wrong. This might be a dumb question, but, in the graphs I have posted, does there look like something is wrong with how I am measuring? Again, I appreciate all your help Some of the best things in life or on HD! | |||
| | #28 (Link) | ||||
You first need to have a proper soundcard cal file using line-out to line-in, that results in a perfectly flat cable loopback measurement. Then you require a microphone or meter that has a reasonably accurate calibration file to be used to take a measurement within its response limits. You're using an HK mic that you have no knowledge of its calibration. Then all the levels have to be set up within defined parameters and a measurement is taken... Then you can assess the results.... brucek | ||||
| | #29 (Link) | |||
| Re: Questions on REW.. I understand. Could the soundcard Line In calibration be used on the mic in side as well? Instead of looping the soundcard through to the Line In, if I disable all effects for the mic In, could I loop it through the mic side? Or is the mic side input too sensitive and too off, to calibrate correctly? The problem is, my soundcard has this auto/detection , that I have to keep turning off. The soundcard is built to change its outputs. the Line In becomes surround out, the Speaker out, becomes main speak out and the mic out becomes center out. if I am not careful and pay attention to whats going on, things can and do change in the settings. The soundcard is almost too complex. Tonight, I will go over the Line In and make sure it stays at Line In and not switches to Stereo In or some other thing. Some of the best things in life or on HD! | |||
| | #30 (Link) | |||||
This extra gain at the mic inputs front end usually results in increased noise. In addition, mic inputs usually enjoy a very limited bandwidth that is designed to comply with a narrow voice frequency range that a cheap microphone would supply. It's just a bad idea to try and use a mic input. If you have a line input, then there is a way to make it work. Quote:
brucek | |||||
| | #32 (Link) | |||
| Re: Questions on REW.. Calibrated Soundcard. I think I know what was the problem. I was using the wrong channel. Right instead of left when using the mic. The help file said right, so thats what I kept using, as soon as I switched it to left, I was able to use the Line In to adjust the input volume. I feel so dumb... ![]() This is the soundcard. I can adjust my eq to raise the lower end, but I think I will leave it be. Some of the best things in life or on HD! | |||
| | #40 (Link) | ||||
Anyways..... I made my adjust ment mostly between 50hz-3kz. Thanks for all the help.. Some of the best things in life or on HD! | ||||
| | #41 (Link) | |||||
The SPL meter calibration file for the Radio Shack meter compensates for the meters response problems at the lower end. It does not take care of the fact that it is inaccurate above 1000Hz. So, you should avoid measuring above 1000Hz with the RS meter. If you want to measure full range, we recommend the Galaxy CM-140 SPL meter. brucek | |||||
| | #42 (Link) | |||
| Re: Questions on REW.. Bruce, you have been a ton of help. Is there a .cal file anywhere that has measurements for the RS meter , higher than 200hz? Also, take a look at my graph. Seems the Line In is working perfectly now. I tested soundcard cali, to line in cali. A perfect match. Green is Line In and gold is soundcard via line in. Some of the best things in life or on HD! | |||
