Will my soundcard not work with REW? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
REW Forum
Discuss Will my soundcard not work with REW? in the Subwoofer Equalization | Calibration forum; Will my soundcard not work with REW? I've been trying for a few days to get REW to calibrate my soundcard correctly, but I keep getting this ...
Old 02-17-08, 12:05 AM   #1 (Link)
New Member
Alias: Derek
User: #16230
Since: Jan 2008
dbaldus is offline
I've been trying for a few days to get REW to calibrate my soundcard correctly, but I keep getting this graph after the soundcard calibration no matter what I do:
Because my laptop is extremely cheap (I picked it up at a Black Friday sale last year at Best Buy), I'm starting to think that maybe my soundcard is not able to work with REW. I have tried to include all of the important information on this single screenshot (Device Manager in top left, DirectX Diag Sound tab top right, sound card properties bottom left, and REW sound settings in bottom right):
If there is anything else anyone would like to see, just let me know and I'll post it. Please help me calibrate my soundcard so I can check the frequency response of my room. I just got a PB12-Plus/2 and I want to get the most out of it but I'm confused why this isn't working for me. Any suggestions would be much appreciated...
Thanks!
Old 02-17-08, 08:59 AM   #2 (Link)
REW Author
Alias: John
Loc: UK
JohnM's Avatar
User: #2
JohnM is offline
Re: Will my soundcard not work with REW?
That looks like some sort of EQ preset is being applied, best see if there is a Realtek control panel where effects or equaliser settings can be turned of, maybe something in a Realtek programs group or something in the Control panel.
Old 02-17-08, 09:29 AM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
You're using the mic-in rather than a line-in. REW requires a line-in. Most users of laptops purchase an external USB soundcard so that a line-in is available.
See the HELP FILES:
A soundcard (internal or external) which supports full duplex operation (simultaneous replay and recording) with line inputs and outputs. Inexpensive soundcards are typically adequate, a reference measurement is used to remove the soundcard's frequency response from the measurement. Examples of USB soundcards which have been found to work well are the Soundblaster MP3+, Soundblaster Live! 24-bit USB External and the M-Audio MobilePre-USB. Note that microphone inputs are NOT suitable and should not be used.
Old 02-17-08, 01:06 PM   #4 (Link)
New Member
Alias: Derek
User: #16230
Since: Jan 2008
dbaldus is offline
brucek wrote: View Post
See the HELP FILES:
Thats what I was afraid of. So, in other words, my soundcard will not work with REW? Or do I just need to plug it in somewhere else?
Old 02-17-08, 02:22 PM   #5 (Link)
Alias: brucek
User: #6
brucek is offline
Some of the newer laptops do offer a line -in capability. You can refer to your user manual for this.
Either way, the mic-in setup is not suitable. You need a line-in. An external USB soundcard is very inexpensive...
Old 02-17-08, 02:56 PM   #6 (Link)
New Member
Alias: Derek
User: #16230
Since: Jan 2008
dbaldus is offline
Okay, so now I'm trying this on my Desktop computer, which has an internal SB Audigy2 ZS. I followed this guide, post #3, http://www.hometheatershack.com/foru...html#post40694, to set everything up. Here is what I am getting for my soundcard calibration now:
I'm concerned about the noise toward the upper end of the graph... is that normal or am I doing something wrong?
I'm actually starting to wonder if maybe it is my cable that I bought to use with the SPL meter's Analog output. The tag on it says "1/8" mono miniplug to RCA phono plug". Is that the right one?
Old 02-17-08, 03:17 PM   #7 (Link)
Alias: brucek
User: #6
brucek is offline
The cable to do a soundcard calibration will be different than the cable used with the SPL meter.
The soundcards line-in and line-out are usually stereo. So you need to 'break out' this signal into its left and right channels before connecting the line-out to line-in.
This requires an adapter such as these:
Depending on the adapter used, you require a different cable.
For the SPL meter, you require an RCA from the Radio Shack meter. Then the adapter determines the other end of that cable.
Similar Threads
REW and Edirol UA-1EX: Anyone get this to work on a mac? goatwuss REW Forum 32 05-25-08 09:53 AM
Another REW work in progress. Blimp REW Forum 6 11-09-07 04:13 PM
Anyone get REW/soundblaster to work with Vista? cruzmisl REW Forum 7 08-29-07 04:26 PM
Will my Sound Blaster Audigy 2 ZS work in REW? bobmills REW Forum 8 06-01-07 05:19 PM
How to make all this work (SPL to REW to BFD) help rlammi REW Forum 87 08-10-06 09:10 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
