| REW Forum first graph...?Discuss first graph...? in the Equalization | Calibration forum; first graph...? hello!
made my first run...
for instance in this first graph......whats the right way to approach "the set target level", ... |
Views: 565 - Replies: 15
| first graph...? hello! made my first run... for instance in this first graph......whats the right way to approach "the set target level", before running the find filter peak..? #1: set target level to 72 dB to level down frequencies to match the very low level between 20-27hz? or #2:Leave target level as in graph and do nothing about the missing low freq? or #3:find if possible... new place for sub or #4:Move furnish in the room ![]() thanks!/H Equipment to tame: Velodyne spl1200R | ||||
| | #3 | ||||||
| Re: first graph...? Quote:
If you’re intending to let REW ato-equalize, you probably have the target set about right Quote:
Regards, Wayne | ||||||
| | #4 | ||||||
| Re: first graph...? hi! Quote:
ok...so half way between dips and peaks to start with.... ok.. ![]() Quote:
are there any general "rules" how much decrease (in dB)/filter setting you can use?...or can you use whatever the "fbq2496" can adjust down..so to speak?...if you know what i mean..(sorry in case of bad english!.. ![]() thanks!/H | ||||||
| | #5 | |||||
Have you tried any other locations? Usually a good corner will get you the best extension. Regards, Wayne | |||||
| | #6 | |||||
i'm gonna check the locations again...must be somewhere in room it's better.. ![]() or ...maybe perhaps it's my seating position thats in a low freq null place.. ![]() thanks/H | |||||
| | #8 | ||||
| Re: first graph...? hi! yes i tried phase at 0,90,180,270 degrees...no difference... maybe room is bad for low freq?... (have an permanent opening into hall,kitchen)..... regards/H | ||||
| | #10 | |||||
already done that... ![]() sub performs well from 20Hz->up going to stuff the sub around an hour or two now to see if i find anything better...... /H | |||||
| | #11 | ||||
| Re: first graph...? hi!.. ok...measured sub at 8 different locations... and no one is good.....hmmm the closest i get is this one: but then instead i have that nasty dip... ![]() so...... it seems i have to go for the first graph......or? suggestions? ![]() | ||||
| | #12 | ||||
| Re: first graph...? Are you measuring just the sub? Or the sub with the main speakers? It could be the main speakers that are causeing a dip in the 32hz-47hz region. I had a similar problem @ ~70-80hz, ended up being a phase issue and corrected my phase AND xover adjustment on my main front spreakers. Just a thought. | ||||
| | #13 | |||||
it's only the sub...cross over @ 200.... /H | |||||
| | #14 | |||||
back at this side of forum a while now... (been playing with the fbq )i was thinking a little about that first graph i posted (first post).... and about boosting... ![]() as my setup is now.. the sub is running at idle (i can imagine) the sub's volume is at position 1 out of 100! ![]() so whats you opninion in that case? raise the sub volume to atleast 1/3 of possible (that will certanly bring up the low freq-loss that is in graph approx 20-27hz... and then bring down the rest a huge (10-20db)amount probably... or stick with 1/100 volume setting and just boost 20-27 range? or? thanks/Hasse | |||||
| | #15 | |||||
Either method will get the same results, but it’s probably better to just boost the bottom end than to plaster the upper end with a lot of filters (although it does look like you could use some adjustment up there). If you over-do it, your sub will let you know – it’ll start making all kinds of nasty noises. Regards, Wayne | |||||
| | #16 | |||||
i knew i must have missed mention something obvious.... (the level on sub)![]() fyi...had to raise my receivers sub vol to max setting +10db when connection the fbq to get atleast couple of leds to light up...hmm seems Pioneer doesnt put out much volts at subw output... ![]() (fbq input setting at -10db of course) thanks.../H | |||||
