REW Forum
Noob, soundcard help
Discuss Noob, soundcard help in the Equalization | Calibration forum; Noob, soundcard help Hello all sorry if this has been aswered before, I did search the forum but couldn't find what I was ...
Views: 639 - Replies: 1
Old 07-13-06, 11:48 AM   #1
New Member
Alias: Lakey
Loc: I ain't tellin ya!
User: #1331
Since: Jun 2006
  Lakes_Puma is offline
Hello all
sorry if this has been aswered before, I did search the forum but couldn't find what I was looking for.
I have a reasonable spec laptop which I have installed REW on and I would like to connect a microphone to it something like the Behringer ECM8000, what is the best (and cheapest) way of connecting this microphone without using lots of different 'boxes' I have looked at a couple of USB pre-amps/soundcards is this a sensible route and can anyone recommend a good quality one that won't break the bank.
BTW I am in the UK
Many thanks
Old 07-13-06, 12:57 PM   #2
JCD
Golden Bear Mod
Alias: Jacen
JCD's Avatar
Loc: Bay Area, California
User: #53
  JCD is offline
Re: Noob, soundcard help
I'm so under-qualified to answer this, I don't know why I'm even bothering..
but, I've heard that a good USB sound card that has a mic preamp with -48V Phantom Power built in is the M-Audio Mobile Pre . I found one here for $139USD that ships worldwide -- you could probably find something a little closer to home that might get to you quicker/cheaper.
If you had a powered mic, like a RS SPL meter, the M-Audio transit would work too.
JCD
