| REW Forum How would I go about trying to match this response curve? Discuss How would I go about trying to match this response curve? in the Equalization | Calibration forum; How would I go about trying to match this response curve? I have this tested response curve (from the manufacturer) for my mains: How would I go about setting up the ... |
Views: 506 - Replies: 8
| How would I go about trying to match this response curve? I have this tested response curve (from the manufacturer) for my mains: ![]() How would I go about setting up the REW chart setting to potentially match the graph? The scale is obvious, but would I simply keep turning up the volume on the AVR until the flatline is 85hz? 85hz is the level used when testing a studio environment correct? | ||||
| | #2 | ||||
| Re: How would I go about trying to match this response curve? The actual amplitude doesn't really matter, but if you really really want things to line up, just turn up the volume until it reads 85dB. There is no standard SPL for measuring the acoustical performance of a studio. -Mike Bentz ~It's all about compromise~ "It's territorial with the soundboard. So you're mixing and some dude comes by spewing opinions and trying to turn knobs. It's akin to going up to an artist and painting over his unfinished masterpiece. You just want to shove your paint brush up his nose and throw the soundboard out the window!" | ||||
| | #4 | ||||
| Re: How would I go about trying to match this response curve? Bear in mind that was probably measured 1m from the speaker and probably in an anechoic chamber, you will find it difficult to create a similar environment for your measurement so the effects of your room on the response will make it look very different. | ||||
| | #5 | ||||
| Re: How would I go about trying to match this response curve? I'll definitely keep that in mind John. P.S. - Is there an article in this forum regarding full spectrum equalizing? I thought I read one but now I can't find it. | ||||
| | #6 | ||||
| Re: How would I go about trying to match this response curve? You'll never match that graph. It was probably measured with very expensive calibrated equipment in an anechoic chamber. You should look at your room independent of this graph. | ||||
| | #7 | ||||
| Re: How would I go about trying to match this response curve? If you plan on equalizing at higher frequencies, you certainly want to use filters with very low Q so they have a broad effect. Narrow bandwidth equalizing above about 200Hz is a not recommended. REW is designed to suggest filters to reduce modal peaks. This limits you to <~200Hz. Above that a manual method is used for broad bandwidths. brucek | ||||
| | #8 | ||||||
| Re: How would I go about trying to match this response curve? Quote:
Thanks for the responses guys. | ||||||
| | #9 | ||||
| Re: How would I go about trying to match this response curve? Here's one article on full range EQ of the nearfield response of a speaker: http://www.sencore.com/newsletter/July07/EQadjustment.pdf | ||||
